該整理底盤了..
車車在我手上也三年了
最近開起來感覺該對底盤進行大整理了 (感覺有很多東西需要更換:L) 由於下個月要前往美國一個月 考慮是否從那買些材料回來備料 下面這套是42 PIECE的(整套應該NT20000有找) 只是他車種是e38 740..... 728跟740在底盤的零件上通用性高嗎? 還是說建議直接台灣叫料會比較保險(品質)? 以下套件清單: 1 x Front Left Upper Control Arm 1 x Front Right Upper Control Arm 1 x Front Left Lower Control Arm 1 x Front Right Lower Control Arm 1 x Right Sway Bar Link 1 x Left Sway Bar Link 1 x Left Tie Rod End 1 x Right Tie Rod End 1 x Center Drag Link 1x Rear Axle Left Upper Control Arm 1 x Rear Axle Right Upper Control Arm 1 x Rear Left Guide Rod 1 x Rear Right Guide Rod 1 x Left Rear Axle Ball Joint 1 x Right Rear Axle Ball Joint 2 x Snap Rings for Ball Joint 1 x Left Integral Link 1 x Right Integral Link 1 x Left Engine Motor Mount 1 x Right Engine Motor Mount 1 x Left Strut Mount 1 x Right Strut Mount 1x Left Transmission Mount 1 x Right Transmission Mount 1 x Left Rear Sway Bar Link 1 x Right Rear Sway Bar Link 1 x Left Strut Bump Stop 1 x Right Strut Bump Stop 1 x Rear Left Shock Bellow 1 x Rear Right Shock Bellow 1 x Left Front Dust Boot 1 x Right Front Dust Boot 1 x Left Shock Mount 1 x Right Shock Mount 2 x Left Subframe Mount Rear 2 x Right Subframe Mount Rear 1 x Left Rear Centre Front Subframe Bushing 1 x Right Rear Centre Front Subframe Bushing |
所有時間均為台北時間。現在的時間是 10:35 AM。 |
