Engine is difficult to start when hot
1.check the air filter and air intake system, Replace the air filter if it is dirty or contaminated. Check the fresh air intake for restrictions or blockage.
2.check for loose or deteriorated engine ground and clean, tighten or replace as needed.
3.check for needed maintenance. inspect tune-up and service related items such as spark plugs and engine oil condition, and check the operation of the engine fuel and ignition management system.
