舊 2011-08-15, 02:29 PM   #1
shyjin
註冊日期: 2010-09-19
文章: 52
E38 的儀表監控按法分享
之前有看到有先進分享過怎麼在儀表按出E39 E46的一些資訊~
但E38部份可能小弟眼花一直沒找到,今天亂晃一下終於找到了
基本上和E39 E46 是一樣的,只是多了顆鈕~
國外原文直接copy如下,版權不知道那裡來的請不要告我唷~~
終於可以看到水溫這些資訊了
BMW E38
UNLOCKING THE ON-BOARD-COMPUTER (OBC)
To unlock the On-Board-Computer use the two Instrument Cluster buttons (L=Left, R=Right)
1) Press and hold "R" down for 5-6 seconds
2) You'll see TEST NR 01
3) Momentarily press "L"
4) You'll see your vin ID, for instance, mine is 08685
5) ADD THE DIGITS :: 8 + 6 + 8 + 5 = 27
6) press "R" again until you reach TEST NR 19
7) Press "L" to select
8) You'll see "LOCK: ON"
9) Press "L" until you reach "27" (the number that was the addition result)
10) AFTER you have the correct number showing, momentarily press the "R" button
11) Display will revert to TEST NR 01
The OBC is now unlocked
OBC HIDDEN INFORMATION
TEST-NR. 01
FGSTNR: GM8685 (VIN serial number)
K: 7744
BMWTNR: 8387061
CI:12 DI:06 BI:09
DAT: 43/98 (week and year of manufacture)
HW:04 SW:1100/1100
ZYL:08 M:4 S:4095 (cylinders, and what else?)
CAN:02 AEND:14
TEST-NR. 02
(Instrument test)
Only do this test in Ignition Position I or II with the engine not running
TEST-NR. 06
TNK: 7.5/31.0/38.5L (current fuel levels: left, right, total)
TNKANZ: 39.4L PHASE1 (average total fuel level)
TEST-NR. 07
KTMP: xxx°C (engine core temperature)
N: xxxxx U/MIN (engine RPM)
ATMP: +xx.0°C (ambient temperature)
TEST-NR. 08
V: xxx KM/H (current velocity)
TEST-NR. 09
VB: xx.x V (battery voltage)
Useful for battery condition tests. Engine not running value should be above 12V....cranking voltage should not drop below 9V. When fully charged the voltage should show > 14V
TEST-NR. 10
LAND: 02 US (country of sale?)
TEST-NR. 11
EINHEIT 1: F7
EINHEIT 2: FA
EINHEIT 3: 4A
TEST-NR. 12
VANK: xxx.x KM/H
ANK: --:--
TEST-NR. 13
GONG
TEST-NR. 14
DIAG: 1 C7 81 000
DIAG: 2 00 00 000
DIAG: 3 00 00 000
DIAG: 4 00 00 000
DIAG: 5 00 00 000
TEST-NR. 15
PORT A00: xxxxxxxx
PORT A01: 00000111
PORT A02: xx0x0001
PORT A03: 00000011
PORT A04: 000x0101
PORT A05: 001B1111
PORT A06: 00110101
PORT B00: xxxxxxxx
PORT B01: 00100010
PORT B02: xx0x0110
PORT B03: x0111001
PORT B04: 000x1111
PORT B05: 11100111
PORT B06: 00000000
Tests No 15 and 16 show internal register values
TEST-NR. 16
OELTEMP: -48°C
Oil Temperature
TEST-NR. 17
RCC-EMPF.: ----MIN
TEST-NR. 18
(No response)
TEST-NR. 19
LOCK: OFF (press Reset to turn the lock back on)
TEST-NR. 20
KVBR: 1000
KVBR is the correction factor for the fuel-consumption meters. By default it is set to '1000'. Adjustment of this default value will give erroneous MPG figures
TEST-NR. 21
RESET all values to default and LOCK the OBC
shyjin 目前離線   回覆時引用此篇文章
舊 2011-08-15, 02:52 PM   #2
嘉義小董
嘉義小董 的頭像
註冊日期: 2009-07-31
文章: 728
車型: 1
翻譯如下:
BMW E38 打開ON-BOARD-COMPUTER (OBC) 要在儀錶板上使用二個儀器群按鈕(L=Left, R=Right)
1.按著" R"不放5-6秒
2.看測試NR01
3. 一瞬間按" L"
4.看您的vin ID,例如,08685
5.增加數字: : 8 + 6 + 8 + 5 = 27
6. 按" R" 再,直到您到達測試NR 19
7. 按" L" 選擇
8.看" 鎖: ON"
9.按" L" 直到達" 27" (是加法結果)的數字
10.在您有正確數字陳列之後,一瞬間按" R" 按鈕
11.顯示將恢復測試NR01 OBC現在開鎖
OBC暗藏的信息
TEST-NR. 01 FGSTNR : GM8685 (VIN號碼) K : 7744 BMWTNR : 8387061 CI :12二:06雙:09 DAT : 43/98 (星期和年製造) HW :04個SW :1100/1100 ZYL :08 M :4 S :4095 (圓筒,並且什麼其他?) 能:02 AEND :14
TEST-NR. 02 (儀器測試) 只做在燃燒位置的這個測試我或II與不运转的引擎
TEST-NR. 06 TNK : 7.5/31.0/38.5L (當前燃料级别: 左,正確,共計) TNKANZ : 39.4L PHASE1 (平均总的燃料水平)
TEST-NR. 07 KTMP : xxx°C (引擎核心温度) N : xxxxx U/MIN (發動機每分鐘轉數) ATMP : +xx.0°C (周围温度)
TEST-NR. 08 v : xxx KM/H (當前速度)
TEST-NR. 09 VB : xx.x v (電池電壓) 有用為電池情况測試。 引擎不連續價值應該在12V之上….加速的電壓不應該在9V之下下降。 當充分地充電電壓應該顯示> 14V
TEST-NR. 10 土地: 02美國(销售国?)
TEST-NR. 11 EINHEIT 1 : F7 EINHEIT 2 : FA EINHEIT 3:4 A
TEST-NR. 12 VANK : xxx.x KM/H ANK : --:--
TEST-NR. 13
TEST-NR. 14 DIAG : 1 C7 81 000 DIAG : 2 00 00 000 DIAG : 3 00 00 000 DIAG : 4 00 00 000 DIAG : 5 00 00 000
TEST-NR. 15 口岸A00 : xxxxxxxx 口岸A01 : 00000111 口岸A02 : xx0x0001 口岸A03 : 00000011 口岸A04 : 000x0101 口岸A05 : 001B1111 口岸A06 : 00110101 口岸B00 : xxxxxxxx 口岸B01 : 00100010 口岸B02 : xx0x0110 口岸B03 : x0111001 口岸B04 : 000x1111 口岸B05 : 11100111 口岸B06 : 00000000 试验沒有15和16证明内部寄存器價值
TEST-NR. 16 OELTEMP : -48°C 油温
TEST-NR. 17 RCC-EMPF. : ----分鐘
TEST-NR. 18 (無回應)
TEST-NR. 19 鎖: (翻回鎖的新聞重新設置)
TEST-NR. 20 KVBR : 1000年 KVBR是燃料消耗量的修正系數。 原廠情况下它被設置為' 1000'。 這缺省值的調整將給錯誤MPG形象
TEST-NR. 21 重新設置所有價值默認和鎖OBC
此篇文章於 2011-08-15 02:57 PM 被 嘉義小董 編輯。
嘉義小董 目前離線   回覆時引用此篇文章
舊 2012-10-17, 05:18 PM   #3
ccdj77
註冊日期: 2012-10-16
文章: 37
車型: 735ial
非常有用訊息.給你一個贊.
ccdj77 目前離線   回覆時引用此篇文章
舊 2012-10-17, 06:09 PM   #4
台南--ㄚ憲
台南--ㄚ憲 的頭像
註冊日期: 2011-05-28
文章: 212
車型: E38 & E46
我還是有看沒有懂...:L
哈哈哈哈
是人窮不是心肝硬!!
台南--ㄚ憲 目前離線   回覆時引用此篇文章
舊 2012-10-17, 06:23 PM   #5
6777jk
6777jk 的頭像
註冊日期: 2012-09-01
車型: e38-735iL
恨我當初不愛唸書……我也是有看沒有懂
大家好~~~我是南投-阿憲
6777jk 目前離線   回覆時引用此篇文章
舊 2012-10-20, 09:59 PM   #6
kunio
kunio 的頭像
註冊日期: 2012-09-03
文章: 135
車型: e38730i
我也是不懂??
一切都是幻覺,嚇不倒我的!!:p
kunio 目前離線   回覆時引用此篇文章
舊 2012-10-20, 11:29 PM   #7
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
BMW E38 打開ON-BOARD-COMPUTER (OBC) 要使用到儀錶板上左邊及右邊的兩個按鈕!
1.按著右邊按鈕5-6秒不放
2.看到
出現測試項目NR01
3.馬上按下儀錶板左邊按鈕
4.查看你車身號碼的後五碼,例如,08685
5.把這後五碼相加,即
8 + 6 + 8 + 5 = 27
6.再按儀錶上的右邊按鈕,
選到測試項目NR 19
7.
當出現測試項目NR 19的時候,按下儀錶左鍵
8.看到儀錶跳"LOCK:ON"
9.按下儀錶左鍵, 直到
出現" 27
10.當儀錶板正確的輸入相映數值(27)時,按下儀錶右邊的按鈕
11.儀錶板將會跳回測試項目NR 01,這時OBC已經解鎖,可以看到隱藏的功能
建議4.和5.這兩個步驟可以先準備好(先算好),到時就可以直接輸入!
此篇文章於 2012-10-20 11:38 PM 被 ctc667712s 編輯。 原因: 有更好的步驟.
ctc667712s 目前離線   回覆時引用此篇文章
舊 2012-10-20, 11:57 PM   #8
阿嘎
阿嘎 的頭像
註冊日期: 2012-10-04
文章: 236
車型: E46 322222
有點複雜..
口袋深一點 車就會好一點
阿嘎 目前離線   回覆時引用此篇文章
舊 2012-10-24, 05:22 PM   #9
hilson
hilson 的頭像
註冊日期: 2012-09-11
住址: 彰化縣
文章: 48
作者: ctc667712s 查看文章
1.按著右邊按鈕5-6秒不放
2.看到
出現測試項目NR01
3.馬上按下儀錶板左邊按鈕
5.把這後五碼相加,即
8 + 6 + 8 + 5 = 27
6.再按儀錶上的右邊按鈕,
選到測試項目NR 19
7.
8.看到儀錶跳"LOCK:ON"
9.按下儀錶左鍵, 直到
出現" 27
清楚多了,感謝分享
hilson 目前離線   回覆時引用此篇文章
舊 2012-10-24, 07:37 PM   #10
純白凝玉
純白凝玉 的頭像
註冊日期: 2012-09-28
文章: 85
車型: V8-E38
作者: hilson 查看文章
清楚多了,感謝分享
這些好麻煩啊..我蓮用都不敢用>>>是方向燈桿上那個BC紐吧....:L
純白凝玉 目前離線   回覆時引用此篇文章
舊 2012-11-02, 08:35 PM   #11
mq1189
註冊日期: 2012-02-26
文章: 58
謝謝分享...今天摸了一遍...還不錯玩
mq1189 目前離線   回覆時引用此篇文章
舊 2015-06-23, 01:14 AM   #12
lin0416
註冊日期: 2011-07-04
車型: none
謝謝分享
lin0416 目前離線   回覆時引用此篇文章
舊 2015-07-17, 10:52 AM   #13
suma
註冊日期: 2015-07-16
車型: F30
謝謝分享
suma 目前離線   回覆時引用此篇文章
舊 2015-07-17, 09:08 PM   #14
712
註冊日期: 2014-11-19
找了好久,終於找到了,明天來試試看,感謝分享!
712 目前離線   回覆時引用此篇文章
舊 2015-07-17, 10:02 PM   #15
andy.ctm
andy.ctm 的頭像
註冊日期: 2015-05-26
文章: 341
車型: e28>e34>e90 320D
放心玩吧,不會玩壞的,這裡高手多
柴油車友也可加我的Line,來柴油群組打屁閒聊唷,記得告訴我是CCT車友,Line ID:0932465448
也有一個柴油車的facebook社團https://www.facebook.com/groups/Diesel.Club.TW/
凡是(車)的租賃、買賣、保險...等任何問題,車友們可以問我,我會就我所知的回答。
PRO普羅租車: 張達明 0932-465-448
andy.ctm 目前離線   回覆時引用此篇文章
舊 2015-08-29, 11:43 AM   #16
Ricky0921
Ricky0921 的頭像
註冊日期: 2015-08-23
感謝樓主無私地分享!
Ricky0921 目前離線   回覆時引用此篇文章
舊 2015-08-29, 01:02 PM   #17
offalan
offalan 的頭像
註冊日期: 2014-05-25
文章: 118
車型: E39 540 + G 37
請問一下,有大大知道下列的意思???
TEST-NR. 09
(1) Engine not running value should be above 12V==>什麼意思,未發動引擎時電壓要在12v 以上嗎???
(2)cranking voltage should not drop below 9V.====>發動中的舜間電壓值是不能低於  9v 嗎????
(3) When fully charged the voltage should show > 14V  ===>發動後,電壓值都在14以下嗎????
4400 cc + 3700 cc
NA還是要大排氣量才過癮。
如果都可以上蝸牛就好了。
offalan 目前離線   回覆時引用此篇文章
舊 2015-08-29, 03:19 PM   #18
MIO
註冊日期: 2013-04-07
文章: 1,063
作者: offalan 查看文章
請問一下,有大大知道下列的意思???
TEST-NR. 09
我的是 1.未發動約12.7V 2.瞬間發動約10.5V 3.發動後約14.6 所已發動後電壓值是14V以上 大家參考
MIO 目前離線   回覆時引用此篇文章
舊 2015-08-30, 01:24 PM   #19
offalan
offalan 的頭像
註冊日期: 2014-05-25
文章: 118
車型: E39 540 + G 37
作者: MIO 查看文章
我的是
你是528車款
我是 E39 540
1.未發動約12 V
2.瞬間發動約10.9V
3.發動後約13.5~14V
我覺得我發動後的電壓,太低了。
4400 cc + 3700 cc
NA還是要大排氣量才過癮。
如果都可以上蝸牛就好了。
舊 2015-08-30, 06:02 PM   #20
畢波
註冊日期: 2014-01-24
文章: 163
車型: E39 E61
作者: shyjin 查看文章
終於可以看到水溫這些資訊了
BMW E38
TEST-NR. 01
K: 7744
BMWTNR: 8387061
CI:12 DI:06 BI:09
HW:04 SW:1100/1100
CAN:02 AEND:14
TEST-NR. 02
(Instrument test)
TEST-NR. 06
TEST-NR. 07
TEST-NR. 08
TEST-NR. 09
TEST-NR. 10
TEST-NR. 11
EINHEIT 1: F7
EINHEIT 2: FA
EINHEIT 3: 4A
TEST-NR. 12
VANK: xxx.x KM/H
ANK: --:--
TEST-NR. 13
GONG
TEST-NR. 14
DIAG: 1 C7 81 000
DIAG: 2 00 00 000
DIAG: 3 00 00 000
DIAG: 4 00 00 000
DIAG: 5 00 00 000
TEST-NR. 15
PORT A00: xxxxxxxx
PORT A01: 00000111
PORT A02: xx0x0001
PORT A03: 00000011
PORT A04: 000x0101
PORT A05: 001B1111
PORT A06: 00110101
PORT B00: xxxxxxxx
PORT B01: 00100010
PORT B02: xx0x0110
PORT B03: x0111001
PORT B04: 000x1111
PORT B05: 11100111
PORT B06: 00000000
TEST-NR. 16
OELTEMP: -48°C
Oil Temperature
TEST-NR. 17
RCC-EMPF.: ----MIN
TEST-NR. 18
(No response)
TEST-NR. 19
TEST-NR. 20
KVBR: 1000
TEST-NR. 21
畢波 目前離線   回覆時引用此篇文章
舊 2015-08-30, 06:03 PM   #21
畢波
註冊日期: 2014-01-24
文章: 163
車型: E39 E61
作者: 嘉義小董 查看文章
翻譯如下:
1.按著" R"不放5-6秒
2.看測試NR01
3. 一瞬間按" L"
7. 按" L" 選擇
8.看" 鎖: ON"
OBC暗藏的信息
TEST-NR. 13
TEST-NR. 18 (無回應)
畢波 目前離線   回覆時引用此篇文章
舊 2016-02-28, 09:51 PM   #22
ericl
註冊日期: 2016-02-27
感謝分享 ,太好了
ericl 目前離線   回覆時引用此篇文章
舊 2016-04-12, 11:25 AM   #23
jack5281
註冊日期: 2010-11-14
文章: 23
車型: BMW 528i
感謝大大分享好資訊!!!
jack5281 目前離線   回覆時引用此篇文章
舊 2016-05-20, 02:03 PM   #24
clawhealers
註冊日期: 2012-05-06
文章: 28
車型: 01' E38 735iL
感謝分享好用資訊,謝謝
clawhealers 目前離線   回覆時引用此篇文章
舊 2017-02-21, 09:22 PM   #25
sai001
註冊日期: 2017-02-16
sai001 目前離線   回覆時引用此篇文章
舊 2018-09-18, 08:24 PM   #26
Kufuyu
註冊日期: 2018-09-16
車型: E38 728
有看沒有懂
Kufuyu 目前離線   回覆時引用此篇文章
舊 2018-09-27, 08:57 PM   #27
Foreverthw
註冊日期: 2017-07-21
車型: 728i
謝謝分享好資訊,我很需要知道一些電腦的資訊啊(常常按錯)
Foreverthw 目前離線   回覆時引用此篇文章
舊 2018-12-10, 11:08 PM   #28
ranger
註冊日期: 2015-03-23
感謝大大分享實用資訊~
ranger 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 07:42 AM
