請問北部有幾家保養廠可以將e46 m3的電腦編程改成csl程式
請問北部有幾家保養廠可以將e46 m3的電腦編程改成csl程式?感謝!
請問有什麼不同?
For SMG •Launch control at 4500rpm raised from 3500rpm (or 2500rpm in USA) for faster acceleration •"Racing start" •Faster 80 millisecond shifts •Throttle blip on down shift •This CSL SMG Drive Logic Flash will start in A3 unless manually changed by the driver. It will not retain your previous shift mode selection. For DME •Brutal and very aggressive shifts •Rev match is improved even more •No delay or loss of torque •Goes along with the SMG CSL Drive Logic |
Wow , only m3 or Also support 330 SSG ?
所有時間均為台北時間。現在的時間是 05:37 PM。 |
