E39 520 雨刷失常
小弟的e39雨刷最近在啟動電門後,就處於第一段雨刷啟動狀態,無法關閉,不知道論壇神人,對次故障應什麼看法 需要更換整組雨刷馬達嗎?或有台北或宜蘭的維修廠可以推薦,小弟車剛到宜蘭,還沒有找到專修的店家,感謝大家幫忙
雨刷繼電器是否卡住了
昨天有送到朋友推薦的車廠,繼電器沒有問題,雨刷馬達也沒有問題,聽老闆說可能是什麼電腦還是中央控制器的問題,要換掉,是這樣嗎?想聽聽各位先進的意見,這換下去又是10張小朋友,我是不是該換維修廠,目前車還在人家那裡
要從X253 Pin 15 16 及 X332 Pin 4 5 查起 Pin20 是起動雨刷馬達信號 也是關鍵 但這不是一般人能修的 也有可能是方向盤邊那隻雨刷開關有問題 這才是一般人能修的 Pin assignments at connector X253 Pin Type Description / Signal type Connection / Measuring notes 1 Not used 2 A Engine hood signal Underhood light switch 3 Not used 4 Not used 5 E Signal, radio protection for passenger compartment Interior protection control module 6 Not used 7 Not used 8 A Vehicle tilt signal Inclination sensor 9 Not used 10 A Trunk lid open signal Trunk lid locking switch 11 A Trunk lid open signal Trunk lid release switch (interior) 12 A Pressure-sensitive finger guard system signal Left rear window pressure-sensitive finger guard 13 A Crash signal Supplemental restraint system control module 14 Not used 15 E Wiper control I Wiper relay I 16 E Wiper control II Wiper relay II Pin assignments at connector X332 15 A Close window signal hand drive Left rear window motor 16 Not used 17 A Horn signal Anti-theft horn (DWA) 18 A Pump signal Washer pump 19 A Consumer cut-off signal Consumer cut-off splice 20 A Interior lights signal Interior lights splice Pin Type Description / Signal type Connection / Measuring notes 1 E Terminal 30 Fuse F11 2 E Interior lights signal Interior/reading lamp, front 3 E Windshield wash signal Wiper/washer switch 4 E Windshield wipe signal 2 Wiper/washer switch 5 E Windshield wipe signal 1 Wiper/washer switch 20 E Wipers in motion signal Wiper motor https://www.bmwgm5.com/GM3_E39_Removal.htm |
車身電腦在手套箱下靠擋火牆處
三個插頭拔下重插試試 |
我的是 撥到最快的第三段時與第二段的速度ㄧ樣,請問是那裡有問題!
http://goods.ruten.com.tw/item/show?21631236533320 |
| 所有時間均為台北時間。現在的時間是 03:40 AM。 |
