-   -   M Sport Steering?? (http://www.bmwcct.com.tw/forums/showthread.php?t=24108)
boneylee 2009-11-23 05:54 PM
M Sport Steering??
Mine is 528 is no multifunction steering and Now want to change M sport multifunction steering so install directly or need to add some parts to config the button section?
龍仔 2009-11-23 07:12 PM
M Sport Steering??
下面引用由boneylee2009/11/23 05:54pm 發表的內容:
Do you want to install m-sport of bmw 528?
It may need to modify the computer from yuor car! :em06: :em06: :em06:
boneylee 2009-11-23 07:37 PM
M Sport Steering??
Yes, I want to install M5 Steering on my 528.Need to modify the computer!? or just add a wire from audio to steering? or just modify the computer?
龍仔 2009-11-23 08:20 PM
M Sport Steering??
下面引用由boneylee2009/11/23 07:37pm 發表的內容:
Maybe need to set the program of your car computer, should be install switches of in car!This is a very professional ~I am very sorry ~ I can';t give you more about it ~I hope that someone could offer you ~
Because my English is poor ~ :em06: :em06: :em06:
boneylee 2009-11-23 08:43 PM
M Sport Steering??
OH .. Thanks Bro. it';s ok .. ^^
冰上 2009-11-24 01:11 AM
M Sport Steering??
英文這樣還叫破~~
龍哥~別太謙虛了~~~ㄏㄏㄏ
jerry1101 2009-11-24 08:31 PM
M Sport Steering??
As I knew , all the function of the steering got the module set complied with the vehicle computer..................
I am not dare to change it if I needed.
Please survey some professional to see if they are able to do so.
Well , good luck.
Boxy 2009-11-25 12:04 AM
M Sport Steering??
Yes you can certainly retrofit the Msport steering wheel provided there is existing wiring avaialble on your vehicle, where in most cases, they do. What you need is the spring hub for wirings alone with the sports steering wheel and air bag.
Good Luck!
jerry1101 2009-11-25 12:34 AM
M Sport Steering??
Boxy:
You remind the most important part.......air bag^^
Boxy 2009-11-25 12:58 AM
M Sport Steering??
下面引用由jerry11012009/11/25 00:34am 發表的內容:
Boxy:
Problem solved, next~ ;-)
所有時間均為台北時間。現在的時間是 02:43 AM
