WTCC..2006冠軍車..BMW E90 320si......
WTCC 2006 E90 320si......引擎為L4 2.0公升..壓榨出275匹馬力..此引擎是BMW另外生產的賽車引擎..並非市售車2.0引擎下去改的..變速箱為6速序列式(有聽說2007年BMW廠車改用"5速手牌"對抗各家廠隊的6速序列式..這個消息還要查證一下才能確定)..全車採用大量碳纖維鈑件僅重1140公斤..排氣為Schnitzer Motorsports直通排氣管含觸煤(不得超過110分貝)..輪圈17吋(不得低於9公斤)......
圖片取自:germancarfans.com和車訊網......第一張圖為碳纖維進氣歧管 :em05: 規格如下: Length: 4,535 mm Width: 1,845 mm Height: approx. 1,350 mm Wheel base: 2,763 mm Vehicle weight: 1,140 kg (with driver) Engine type: four-cylinder in-line Capacity: 1,998 cc max. output: approx. 275 bhp at approx. 8,400 rpm max. engine speed: 8,500 rpm (as per regulations) Cylinder block: aluminium crankcase reinforced with a bedplate Engine control: BMW Motorsport ECU404 Tank capacity: approx. 45 litres Fuel: standard fuel, Super Plus unleaded Chassis/body: unitary construction steel body Aerodynamic front apron, rear apron, flared front and rear package: wheel arches made of CRFP/GFRP, rear wings made of aluminium Front axle: double joint Mc Pherson axle with adjustable anti roll bar Rear axle: five arms axle with adjustable anti roll bar Shock absorbers: Sachs with adjustable compression and rebound Brake system, front: four-piston AP brake callipers, iron brake discs of 332 mm diameter Brake system, rear: two-piston AP brake callipers, iron brake discs of 280 mm diameter Wheels: aluminium rims, SA 216 BBS Seat: Recaro ProRacer HANS |
好棒的車..不知到有沒有機會開到
:em05: 不過 . . . 你的肚子要先減掉 ! :em04: 模型車 看看就好 ! :em03: :em03: |
哈哈..果然要減肥拉
那個排檔頭真像高爾夫球= ="
baby~E92是AUTO還是原廠滴?
今年表現不曉得怎麼樣阿??
3 個附件
:em03: :em03: |
那請問市售版有320"SI"為名的嗎??
| 所有時間均為台北時間。現在的時間是 07:28 AM。 |
