求救E90 330 亮燈疑問,請問各位大大有人看得懂這是啥?
小弟的e90 330 前幾天行進間時,儀表版中間忽然亮了像一個燈泡裡有個驚嘆燈的圖示(如下圖),過了一下就熄了,但昨天又亮了一次,請問各位大大有人看得懂這是啥?:mad:
燈泡接觸不良
燈具故障燈....最近有換燈具或燈泡嗎??再檢查看看有沒有燈泡沒亮..
哈哈哈!畫的好可愛
通常都是134 or 136 後煞車燈 •FRM 87 Right Rear Light Failure • FRM 88 Dipped Beam Left Failure • FRM 89 Dipped Beam Right Failure • FRM 111 Number Plate Light Left Failure • FRM 113 Sidelights Switched On • FRM 114 Rear Fog Light Failure • FRM 115 Reverse Light Right Failure • FRM 116 Indicator Rear Left Failure • FRM 117 Reverse Light Left Failure • FRM 118 Rear Light Right Failure • FRM 119 Indicator Front Right Failure • FRM 120 Dipped Beam Left Failure • FRM 121 Dipped Beam Right Failure • FRM 122 Indicator Front Right Failure • FRM 123 Rear Light Right Failure • FRM 124 Indicator Right Failure • FRM 125 Indicator Rear Right Failure • FRM 126 Fog Light Right Failure • FRM 127 Side Indicator Left Failure • FRM 128 Left High Beam Failure • FRM 129 Rear Fog Light Failure • FRM 130 Right High Beam Failure • FRM 131 Parking Light Left Front Failure • FRM 132 Front Right Side Light Failure • FRM 133 Right Rear Light Failure • FRM 134 Right Brake Light Failure • FRM 135 Centre Brake Light Failure • FRM 136 Left Brake Light Failure • FRM 137 Number Plate Light Right Failure • FRM 138 Fog Light Left Failure • FRM 196 Indicator Front Right Failure • FRM 197 Indicator Front Left Failure • FRM 231 Light System Failure • FRM 256 Headlight Leveling System Failure • FRM 259 Window Anti-Trap Deactivated • FRM 261 Window Anti-Trap Failure • FRM 345 Brake/Tail Light Failure Right • FRM 346 Brake/Tail Light Failure Left • FRM 371 Number Plate Light Failure • FRM 372 Brake Force Display Light Failure Left • FRM 373 Brake Force Display Light Failure Right • FRM 378 Sidelight/Daytime Lights Defective- Left • FRM 379 Sidelight/Daytime Lights Defective- Right • FRM 380 Turn Signal Lights Defective- Left • FRM 381 Turn Signal Lights Defective- Right • FRM/ALC 295 Adaptive Cornering Lights Failure • FRM 437 Parking Lights On |
這位大大太有才了!! 這都可以用畫的!! 給你一個讚!!
小弟只有改過大燈,謝謝各位大大指點,小弟再去檢查看看
| 所有時間均為台北時間。現在的時間是 09:06 PM。 |
