舊 2013-07-13, 06:47 PM   #1
b91616
註冊日期: 2005-02-22
住址: 台南府城
文章: 1,253
全新~美國進口 f1 racing stage1 240mm 5速手排用輕量化飛輪含離合器片含強化壓板
以下為官網說明~有中文翻譯~全新品一組~多買的一組~自己車上已經裝了一組
全新出售25000元~物品在台南~請聯絡0987539208.阿哲
F1 Racing Stage 1 clutch kit is an upgrade heavy-duty clutch set up for those who seeks streetable high performance clutch. It is a direct factory replacement parts thus no modifications are needed. The clutch kit includes only the highest grade components and it's ready for hot action on street and track. The premium organic friction material for high heat tolerance, quick recovery, good friction and long life. The heavy-duty solid center unit boasts heat treated hub and retainer rivets for the maximum power and durability. The F1 Racing pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. F1 Racing pressure plate provides smooth and precise feel with easy modulation. All F1 Racing pressure plate is load tested on a special testing tool for quality assurance.
F1 Racing Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is made from high carbon alloy steel. It is incredibly durable allowing the user to use just about any clutch disc material available from organic to Kevlar and even sintered iron. The friction plate can be machined or replaced as needed. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
Ultra light and weighs only 10.4 lbs
Meets or exceeds SFI 1.1 specification
Course ground surface to maintain coefficient of friction
Stepped pin to maintain plate balance and placement
Tig-welded safety tab to eliminate ring gear separation
Heilicoil bolt holes to insure proper torque value and eliminate thread damage
A set of brand new 8 ea. flywheel bolts are included
NOTE: Replacement of dual mass flywheel may cause added gear noise
This complete clutch kit and flywheel package includes:
F1 Racing Lightweight Aluminum Racing Flywheel
F1 Racing Heavy-Duty Pressure Plate
F1 Racing Full Face Organic Rigid Street Disc (240mm, 10 spline)
Release Bearing
Pilot Bearing
Alignment Tool
Installation Guide
Horsepower Rating: 342 HP / Torque Capacity: 315 ft/lbs
F1赛车第1阶段离合器套件对于那些谁寻求streetable的高性能离合器是一个升级的重型离合器。这是一种直接的工厂更换零件,因此需要进行任何修改。离合器套件仅包括最高等级的元件,它已经准备好为街道和赛道上的火爆动作。优质的有机摩擦材料的耐热性高,恢复快,良好的摩擦,使用寿命长。重型固体中心单位拥有热处理的枢纽和固定铆钉的最大功率和耐久性。 F1赛车的压盘具有特殊的单膜片设计,增加夹紧力。它设有感应硬化隔膜,数控加工铸件,更强的驱动皮带和铆钉。 F1赛车压盘容易调制,提供平稳和精确的感觉。所有F1赛车压盘是一项特殊的测试工具,质量保证负载测试。
F1赛车铝飞轮,用最高的质量,最现代的材料。飞轮本身是由6061 T6铝坯。数控加工在一个恒定的速度,耐用性和光洁度表面。在摩擦表面由高碳合金钢。这是令人难以置信的耐用允许用户只使用有机芳纶任何离合器片材料,甚至烧结铁。摩擦板可进行机械加工,或根据需要更换。保留强度的飞轮的中心的质量,但在外面的质量被消除以获得最佳性能。
超轻,重量只有10.4磅
符合或超过SFI 1.1规范
当然地面保持的摩擦系数
阶梯脚保持平衡和安置板
TIG焊接安全“选项卡,以消除齿圈分离
Heilicoil螺栓孔,以确保适当的扭矩值和消除螺纹损坏
一组全新的8件。飞轮螺栓
注:更换可能导致加双质量飞轮齿轮噪音
这个完整的离合器和飞轮套件包括:
F1赛车轻量级全铝赛车飞轮
F1赛车场重型压盘
F1赛车全脸有机刚性街光盘(240毫米,10样条)
分离轴承
导轴承
对齐工具
安装指南
马力等级:342马力/扭矩容量:315英尺/磅
04118R0A+04117FA_600.jpg   970050_504284766308720_1235868480_n.jpg   971297_504284746308722_1068433261_n.jpg
此篇文章於 2013-07-13 07:07 PM 被 b91616 編輯。
b91616 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 02:28 AM
