舊 2007-06-28, 04:03 PM   #1
mario2007112
註冊日期: 2007-05-18
住址: 能夠摸魚的地方
文章: 358
有一事請教
http://tw.f2.page.bid.yahoo.com/tw/auction/b27892993?u=cc200500000
http://tw.f5.page.bid.yahoo.com/tw/auction/e14318438?u=cc200500000
http://tw.f4.page.bid.yahoo.com/tw/auction/d17753776?u=cc200500000
請問這三樣東西改了對車會造成傷害嘛~能否有前輩提供意見 :em04:
mario2007112 目前離線   回覆時引用此篇文章
舊 2007-06-28, 05:15 PM   #2
0wnage
註冊日期: 2004-07-21
住址: Evil Empire
文章: 365
有一事請教
[這篇文章最後由0wnage在 2007/06/28 05:45pm 第 2 次編輯]
The pricing is not so good, way too expensive on these stuff.
I don';t really that flywheel is pretty much useful as the drop-in replacement is because that when you greatly reduce the mass of flyhweel you may hit the problem on the balance of the crankshaft then resulting higher engine vibration and low end torque even the flywheel is balanced, that';s the reason why BMW balanced the flywheel and the crankshaft at the same time on the M engines. and it looks like is not possible to put it on the manual tranny. YES, you can get more high-end HP but trade-off the low end torque and higher vibration by doing this.
Okay,why BMW doesn';t make the flywheel of M engine with 3Kg or less?
That is the idea.
The under drive pulley sets..well no idea on the gain would be there is a number comes out from TMS, they claims can get 10+ HP on E46 M3 with lightweight underdrive pulley only, but how much HP you can gain on the E36 325 or 318? probably you';ll get less HP on that. but lightweight underdrive pulley is good to have only if they didn';t changed the original pulley ratio then you can go for it.
Electric Fan set, probably good stuff to go but that is all about the $.
You probably can get 10+HP or something but not 20 or 30HP, but it';s not very worthy anyway with these things(in comparison of $), it just works but noone knows the idea on how much gain would be only if you dyno';ed it.
Do the seller dyno';ed the stuff anyway?
Just my 2 cents.
Magnetro
0wnage 目前離線   回覆時引用此篇文章
舊 2007-06-28, 10:17 PM   #3
菜尾
註冊日期: 2006-10-26
住址: 你媽媽的春天
文章: 1,069
有一事請教
下面引用由mario20071122007/06/28 04:03pm 發表的內容:
http://tw.f4.page.bid.yahoo.com/tw/auction/d17753776?u=cc20050 ...
你的是E46的車嗎?
菜尾 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 01:14 AM
