舊 2006-08-10, 12:29 PM   #1
台中小余
註冊日期: 2004-12-23
文章: 1,825
車型: F02 750LI E63 M6
Yahoo拍賣~天ㄚLOTUS那台是什麼車720hp/106kgm
http://tw.f5.page.bid.yahoo.com/tw/auction/e14760803?u=a0936075339z
LOTUS那台竟然有720匹...一堆超跑被這台車超過時不就很傻眼!
錶速到420...歐買尬...
台中小余 目前離線   回覆時引用此篇文章
舊 2006-08-10, 01:08 PM   #2
那台是歐寶的omega..裡面是VAUXHALL的引擎..市售版應該沒那麼強..應該是又改過的..也屬於限量車..年份1990~1992.
舊 2006-08-10, 01:13 PM   #3
台中小余
註冊日期: 2004-12-23
文章: 1,825
這種型的OMEGA應該很老了!...720匹也太誇張了吧...
台中小余 目前離線   回覆時引用此篇文章
舊 2006-08-10, 01:20 PM   #4
原廠3615cc.引擎並非是LOTUS..是經過LOTUS TWINTURBO 改裝.市售極速165MPH.
舊 2006-08-10, 01:28 PM   #5
377 bhp at 5200rpm.
568 Nm/5500rpm (557 Nm / 4200 rpm,406 Nm / 2000 rpm )
0-100km/h 5.4s
0-200km/h 17.3s
0-100-0km/h 8.6s
0-60mp/h (97km/h) 4.9s
0-100mp/h (161km/h) 11.0s
0-402.33m 13.5s
286km/h
In-line six cylinder 3615cc.Double overhead camshafts,
4valve/cylinder. Lotus-Delco electronic multipoint fuel injection.
Twin Garret T25 Turbochargers each with liquidcooled-
intercoolers 0.7 bar turbopressure.
Reinforced iron cylinderblock,graphite coated pistons,forged-
crankshaft ,reinforced special connecting rods, hardened-
camshafts and modified lubrication system with oil spray
on pistons from underneath.
Rear differential with 45% slip function from Australia
GM Holden Commondore
Front:MacPherson struts with coil springs and triangle -arms,
anti-rollbars. Rear: Multi-links,coilsprings, anti-roll bars.
Gas shock absorbers, with pneumatic self-levelling.
Recirculating ball, rack and pinion, speedsensitive, 2.6 turns
lock-to-lock
AC, Full leather, hard wood, 17" wheels.
Front 8.5-17 235/45-17
Rear 9.5-17 265/40-17
Ventilated discbrakes front and rear Front 330mm with
4-piston racing calipers. Rear 300mm dual-piston racing-
calipers. ABS
Length: 477cm, Width: 181cm Height: 143cm
Wheelbase: 273cm , Track: f 149cm, r 154cm
Weight: 1650kgs(empty). Fuel tank 75litres
http://www.lotusomega.se/public_html/home.htm
舊 2006-08-10, 03:06 PM   #6
台中小余
註冊日期: 2004-12-23
文章: 1,825
阿吉大哥果然是資深前輩阿!
台中小余 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 09:25 PM
