舊 2007-04-15, 01:52 AM   #1
yafayu
註冊日期: 2007-04-14
住址: 多倫多
[貼圖]E92 M3 寶馬美國發表詳細資料
Specifications BMW M3 Coupé.
Body M3
Coupé
No of doors/seats: 2/4
Length/width/height (unladen) : 4,615/1,817/1,418
Wheelbase: 2,761
Track, front/rear: 1,538/1,539
Turning circle: 11.7
Fuel tank: 63L
Cooling system incl heater: 11.4L
Engine oil: 8.8L
Transmission fluid: 2.1L
Final drive fluid: 1.2L
Weight, unladen, to EU1: 1,655kg
Max load to DIN : 500kg
Max permissible weight to DIN: 2,080kg
Max axle load, front/rear: 1,020/1,120kg
Max roofload/trailer download: 75kg
Luggage compartment to DIN: 400L
Air drag: 0.684 Cd x A
Engine
Config/No of cyls/valves: V8/4
Engine management: MS S60
Capacity: 3,999cc
Bore/stroke: 92.0/75.2 mm
Compression ratio : 12.0 : 1
Fuel grade : 98 (95) RON
Max output: 309/420 kW/hp @ 8,300rpm
Max torque: 400/295 Nm/lb-ft @ 3,900rpm
Chassis and Suspension
Suspension, front
Aluminium two-joint spring strut axle with tiebar;
small, positive compensation of transverse forces; reduction of brake dive
Suspension, rear
Five-arm axle with anti-squat and anti-dive
Brakes, front
Single-piston swing-calliper compound disc brakes
Diameter
mm
360 x 30, vented and cross-drilled
Brakes, rear
Diameter
mm
350 x 24, vented and cross-drilled
Driving stability systems
ABS, ASC, CBC, DSC; variable M differential lock
Steering
Rack-and-pinion steering with hydraulic assistance and Servotronic
Steering ratio, overall 12.5:1
Type of transmission
SG 6
Gear ratios
I 4.055:1
II : 2.369:1
III : 1.582:1
IV : 1.192
V : 1:1
VI : 0.872:1
VII : -
R: 3.678: 1
Final drive ratio
3.846 : 1
Tyres, front/rear
245/40 ZR18 / 265/40 ZR18
Rims, front/rear
8.5J x 18 EH2+ IS 29 aluminium, forged/9.5J x 18 EH2+ IS 23 aluminium, forged
Performance
Power-to-weight ratio to DIN: 5.1 kg/kW
Output per litre: 77.3/105.1 kW/hp
Acceleration 0–100 km/h: 4.8 sec
Top speed: 250 km/h
Fuel Consumption
Urban
ltr/100 km
17.9
Extra-urban
ltr/100 km
9.2
Composite
ltr/100 km
12.4
CO2
g/km
295
Miscellaneous
Emission standard
EU4
1Weight of car in road trim (DIN) plus 75 kg for driver and luggage. 2May be increased under certain conditions. 3Electronically limited.
[br][br]-=-=-=-=- 以下內容由 yafayu2007年04月15日 02:34am 時新增 -=-=-=-=-
4公升炸出420匹馬力, 這顆引擎準備會是2008的Engine of the Year了!! 先來恭喜BMW吧! 再次創出新的紀錄
yafayu 目前離線   回覆時引用此篇文章
舊 2007-04-15, 03:56 AM   #2
yafayu
註冊日期: 2007-04-14
住址: 多倫多
http://www.worldcarfans.com/news.cfm...gine-in-detail
舊 2007-04-15, 10:16 AM   #3
naimalajumbo
naimalajumbo 的頭像
註冊日期: 2005-05-18
住址: 桃園的小Q
文章: 3,542
這些小零件的組成可以創造出那麼吸引人的動力....
期待NEW M3在台灣的身影.... :em15: :em15:
naimalajumbo 目前離線   回覆時引用此篇文章
舊 2007-04-15, 03:59 PM   #4
連長
連長 的頭像
註冊日期: 2002-09-30
文章: 2,926
車型: E34-540
台灣不知何時可以看到它的身影?
連長 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 06:37 AM
