舊 2012-10-21, 01:45 PM   #1
wang801216
註冊日期: 2006-07-05
文章: 202
E39儀表板自我測試功能的第14項的故障記憶
請問大大們.E39儀表板自我測試功能的第14項的故障記憶(be883c.bfc841.c78100.d781d2.878200.)共5項故障碼.不知道是甚麼故障問題是否可以解答,先謝謝大大們
wang801216 目前離線   回覆時引用此篇文章
舊 2012-10-22, 01:32 PM   #2
wang801216
註冊日期: 2006-07-05
文章: 202
自己頂一下.
舊 2012-10-22, 05:03 PM   #3
儀表板的測試 14項是儲存電腦中的故障碼!
取前的數字為代表意思
14.0 BEC82D BE代表燈光模組內部的錯誤( LCM internal error)
14.1 834228 8代表右邊的浮筒有問題(Fuel level sensor 1 )
14.2 D78115 D7代表左邊的浮筒有問題(Fuel tank sensor 2)
1 Fuel consuming signal from engine control unit faulty
2 Fuel consuming signal (ti-II) from engine control unit faulty
3 Road signal from ABS/ASC/DSC control unit faulty
4 RPM (tD) from engine control unit faulty
5 Coolant temperature sensor faulty
6 Temperature sensor
7 Outside temperature sensor
8 Fuel level sensor 1 (Fuel pump side)
9 Fuel level sensor 2 (without fuel pump)
10 Tension to high at the power supply
11 EGS signal disturbed
12 Power supply Pin 15
13 Power supply Pin R
14 Service Interval Display (SAI) Reset
15 Pressure Switch
16 Gong Sound (T1)
17 Gong Sound (T2)
18 Gong Sound (T3)
19 Current to high in the instrument cluster
20 Internal error in the LCM module
21 Internal error (IKE)
22 Vehicle speed signal (Tacho-A)
23 Instrument cluster -Bus (I-Bus)
24 Body-Bus (K-Bus)
25 Error during activation of the instrument in the instrument cluster
26 Undefined error
27 Internal Error
28 I-BUS error
29 Power Supply
30 Power Supply
31 Power Supply
32 Power Supply
33 K-BUS
34 Oil Pressure Control Light
35 Reverse gear recognition
3E Error by activation display
3F Instrument cluster current to high
44 Oil pressure switch
87 Body-Bus (K-Bus)
88 (I-Bus)
8B Gong Ton (T3)
8C Power supply Term. R
8D EGS Data lead disturbed
8F Power supply
90 Power supply Term. 15
91 Gong Ton (T2)
92 Gong Ton (T1)
BC Break fluid level
BD Electronic break power
BE LCM internal error
BF Instrument Cluster Internal Error
C1 ABS/ASC/DSC Signal(Tacho)
C3 RPM signal from DME control unit
C6 Output PIN 6 (Code EWS)
C7 Fuel tank sensor 1 (fuel pump side)
CD Fuel consumption signal DME 1
CE Outside temperature sensor
CF Service Interval Display (SIA) Reset
D3 Coolant temperature sensor
D5 Oil temperature sensor
D7 Fuel tank sensor 2 (without fuel pump)
DA Fuel consumption signal DME 2
F0 CAN-Bus off
F4 CAN Identification missing
F5 CAN Identification missing (ASC)
F6 CAN Identification missing (DME)
F7 CAN Identification missing (DME)
F8 CAN Identification missing (DME)
F9 CAN Identification missing (DME)
FA CAN Identification missing (EML)
FB CAN Identification missing (EGS)
FC CAN Identification missing
FD CAN Identification missing
舊 2012-10-22, 07:37 PM   #4
paul0917
註冊日期: 2012-03-04
文章: 104
超好用的資訊,感謝樂大
paul0917 目前離線   回覆時引用此篇文章
舊 2012-10-25, 12:35 PM   #5
wang801216
註冊日期: 2006-07-05
文章: 202
知道了..感謝樂大
所有時間均為台北時間。現在的時間是 01:52 PM
