舊 2015-01-28, 04:03 PM   #1
jacky270
註冊日期: 2012-01-22
文章: 350
尋找南部高雄改ESS
最近一直被狂電~~加上車上了年紀~01年330~是否有人可介紹~小弟想擴缸3200加裝ESS第二階~新的實在有點貴~最好是中古良品~~還是有什麼可建議的呢~謝謝
jacky270 目前離線   回覆時引用此篇文章
舊 2015-01-29, 08:28 PM   #2
菜尾
註冊日期: 2006-10-26
住址: 你媽媽的春天
文章: 1,069
找西螺正輝,包你催到爽
菜尾 目前離線   回覆時引用此篇文章
舊 2015-01-29, 09:14 PM   #3
jacky270
註冊日期: 2012-01-22
文章: 350
有點遠~~只想找高雄的~~謝謝
舊 2015-01-30, 08:07 AM   #4
ElvisWang
註冊日期: 2014-08-12
住址: 屏東;墨西哥
車型: E38 738
請問ESS是增壓嗎?
小弟也想了解一下!!!
可以加入LINE交流嗎
elviswangmp732
ElvisWang 目前離線   回覆時引用此篇文章
舊 2015-01-30, 08:44 AM   #5
CTK1980
註冊日期: 2007-10-30
住址: TAIPEI
文章: 363
作者: ElvisWang 查看文章
請問ESS是增壓嗎?
小弟也想了解一下!!!
可以加入LINE交流嗎
elviswangmp732
可考慮AA啊...
Active Autowerke’s supercharger kit for the BMW E46 330i delivers instantaneous power and low end torque in amounts far beyond what the bimmer factory gods intended. Specifically designed to run with 91-93 octane pump fuel and your stock engine management system, this system uses our dyno-tuned software adjustments to manage ignition, fuel, vanos, rev limits, speed governors, etc – all programmed into the same on-board computer your BMW 330i was born with.
So the performance mutation from normal to ‘extra-assertive’ is smooth and dependable, and totally reversible to stock. Even our oil cooling upgrade is self contained and non-intrusive of the factory oil system. Nothing beats a complete bolt on supercharger system.
Bottom line: you get to experience M3 performance in a 330i at an incredibly affordable price. No need to sacrificing driveability, comfort, integrity or amenities that you have grown to love. That’s an evolution worth pursuing.
Performance Specs
Power: 365 BHP @ 7000 rpm
Torque: 270 ft/lbs @ 5400 rpm
Boost Level: 8.0 psi
Key Features:
  • Rotrex C38-81 trim supercharger
  • 8 psi boost level
  • CNC machined supercharger bracket with hardware
  • Self-contained oil system with front-mount oil cooler
  • 6 higher flowing fuel Injectors
  • Active Autowerke/Bosch bypass valve
  • High temperature silicone hoses with stainless clamps
  • All mandrel bent tubing for improved flow
  • Active Autowerke Air Filter (Some Models may use K&N)
  • Active Autowerke Dyno-Tuned Software
  • All mounting hardware, plumbing, hoses and clamps
  • Illustrated instruction manual & installation guide
  • 2 Year Warranty with free tech support
CTK1980 目前離線   回覆時引用此篇文章
舊 2015-01-30, 09:43 AM   #6
jacky270
註冊日期: 2012-01-22
文章: 350
其實只要是進口的都有考慮~但新品真的有點貴~~所以才想找中古良品但可遇不可求~~問了很多車主都使用ESS
LINE ID 0939247536
所有時間均為台北時間。現在的時間是 05:04 PM
Powered by vBulletin® 版本 2024
版權所有 ©2000 - 2024,BMWCCT.
