舊 2007-09-27, 04:41 PM   #1
giovi--lee
註冊日期: 2002-12-21
文章: 140
WTCC..2006冠軍車..BMW E90 320si......
WTCC 2006 E90 320si......引擎為L4 2.0公升..壓榨出275匹馬力..此引擎是BMW另外生產的賽車引擎..並非市售車2.0引擎下去改的..變速箱為6速序列式(有聽說2007年BMW廠車改用"5速手牌"對抗各家廠隊的6速序列式..這個消息還要查證一下才能確定)..全車採用大量碳纖維鈑件僅重1140公斤..排氣為Schnitzer Motorsports直通排氣管含觸煤(不得超過110分貝)..輪圈17吋(不得低於9公斤)......
圖片取自:germancarfans.com和車訊網......第一張圖為碳纖維進氣歧管 :em05:
規格如下:
Length: 4,535 mm
Width: 1,845 mm
Height: approx. 1,350 mm
Wheel base: 2,763 mm
Vehicle weight: 1,140 kg (with driver)
Engine type: four-cylinder in-line
Capacity: 1,998 cc
max. output: approx. 275 bhp at approx. 8,400 rpm
max. engine speed: 8,500 rpm (as per regulations)
Cylinder block: aluminium crankcase reinforced with a bedplate
Engine control: BMW Motorsport ECU404
Tank capacity: approx. 45 litres
Fuel: standard fuel, Super Plus unleaded
Chassis/body: unitary construction steel body
Aerodynamic front apron, rear apron, flared front and rear
package: wheel arches made of CRFP/GFRP, rear wings made of aluminium
Front axle: double joint Mc Pherson axle with adjustable anti roll bar
Rear axle: five arms axle with adjustable anti roll bar
Shock absorbers: Sachs with adjustable compression and rebound
Brake system, front: four-piston AP brake callipers, iron brake discs of 332 mm diameter
Brake system, rear: two-piston AP brake callipers, iron brake discs of 280 mm diameter
Wheels: aluminium rims, SA 216 BBS
Seat: Recaro ProRacer HANS
giovi--lee 目前離線   回覆時引用此篇文章
舊 2007-09-27, 04:45 PM   #2
giovi--lee
註冊日期: 2002-12-21
文章: 140
舊 2007-09-27, 04:47 PM   #3
giovi--lee
註冊日期: 2002-12-21
文章: 140
舊 2007-09-27, 04:49 PM   #4
giovi--lee
註冊日期: 2002-12-21
文章: 140
舊 2007-09-27, 05:07 PM   #5
joy0951
註冊日期: 2007-08-07
住址: 北極速--新店
文章: 1,880
好棒的車..不知到有沒有機會開到
joy0951 目前離線   回覆時引用此篇文章
舊 2007-09-27, 05:21 PM   #6
BABY
註冊日期: 2003-12-25
住址: 寶寶的嬰兒房
文章: 4,903
贊助: 2005、2006、2007
下面引用由joy09512007/09/27 05:07pm 發表的內容:
好棒的車..不知到有沒有機會開到
你有國際賽車執照(FIA)認可 ! 就有可能 . . . . :em01: :em01:
:em05: 不過 . . . 你的肚子要先減掉 ! :em04:
模型車 看看就好 ! :em03: :em03:
BABY 目前離線   回覆時引用此篇文章
舊 2007-09-27, 06:02 PM   #7
joy0951
註冊日期: 2007-08-07
住址: 北極速--新店
文章: 1,880
哈哈..果然要減肥拉
舊 2007-09-28, 12:21 PM   #8
紅鬃烈馬
紅鬃烈馬 的頭像
註冊日期: 2005-03-17
住址: 下港
文章: 614
那個排檔頭真像高爾夫球= ="
紅鬃烈馬 目前離線   回覆時引用此篇文章
舊 2007-09-30, 05:34 PM   #9
玉羅煞
玉羅煞 的頭像
註冊日期: 2004-03-07
住址: ~南迴山道~
文章: 445
baby~E92是AUTO還是原廠滴?
玉羅煞 目前離線   回覆時引用此篇文章
舊 2007-10-01, 10:02 PM   #10
eminem
註冊日期: 2004-02-25
住址: 慕尼黑
文章: 433
今年表現不曉得怎麼樣阿??
eminem 目前離線   回覆時引用此篇文章
舊 2008-02-09, 05:43 AM   #11
BABY
註冊日期: 2003-12-25
住址: 寶寶的嬰兒房
文章: 4,903
贊助: 2005、2006、2007
下面引用由玉羅煞2007/09/30 05:34pm 發表的內容:
baby~E92是AUTO還是原廠滴?
:em11: 咦 ~ ! 去年的 . . . . 歹勢沒看到 ! 這台是E90 320 #1. 廠版的 . :em03:
:em03: :em03:
BABY 目前離線   回覆時引用此篇文章
舊 2008-02-09, 05:16 PM   #12
mimi
註冊日期: 2007-10-22
文章: 34
那請問市售版有320"SI"為名的嗎??
mimi 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 03:59 PM
Powered by vBulletin® 版本 2024
版權所有 ©2000 - 2024,BMWCCT.
