[貼圖]E92 M3 寶馬美國發表詳細資料
http://www.bimmerpost.com/images/mw1.jpg
http://www.bmwusa.com/nr/rdonlyres/9...mage_m3_fv.jpg http://dream.imgz.info/200704/200704...cf6061339a.jpg http://dream.imgz.info/200704/200704...fd9dde8afd.jpg Specifications BMW M3 Coupé. Body M3 Coupé No of doors/seats: 2/4 Length/width/height (unladen) : 4,615/1,817/1,418 Wheelbase: 2,761 Track, front/rear: 1,538/1,539 Turning circle: 11.7 Fuel tank: 63L Cooling system incl heater: 11.4L Engine oil: 8.8L Transmission fluid: 2.1L Final drive fluid: 1.2L Weight, unladen, to EU1: 1,655kg Max load to DIN : 500kg Max permissible weight to DIN: 2,080kg Max axle load, front/rear: 1,020/1,120kg Max roofload/trailer download: 75kg Luggage compartment to DIN: 400L Air drag: 0.684 Cd x A Engine Config/No of cyls/valves: V8/4 Engine management: MS S60 Capacity: 3,999cc Bore/stroke: 92.0/75.2 mm Compression ratio : 12.0 : 1 Fuel grade : 98 (95) RON Max output: 309/420 kW/hp @ 8,300rpm Max torque: 400/295 Nm/lb-ft @ 3,900rpm Chassis and Suspension Suspension, front Aluminium two-joint spring strut axle with tiebar; small, positive compensation of transverse forces; reduction of brake dive Suspension, rear Five-arm axle with anti-squat and anti-dive Brakes, front Single-piston swing-calliper compound disc brakes Diameter mm 360 x 30, vented and cross-drilled Brakes, rear Single-piston swing-calliper compound disc brakes Diameter mm 350 x 24, vented and cross-drilled Driving stability systems ABS, ASC, CBC, DSC; variable M differential lock Steering Rack-and-pinion steering with hydraulic assistance and Servotronic Steering ratio, overall 12.5:1 Type of transmission SG 6 Gear ratios I 4.055:1 II : 2.369:1 III : 1.582:1 IV : 1.192 V : 1:1 VI : 0.872:1 VII : - R: 3.678: 1 Final drive ratio 3.846 : 1 Tyres, front/rear 245/40 ZR18 / 265/40 ZR18 Rims, front/rear 8.5J x 18 EH2+ IS 29 aluminium, forged/9.5J x 18 EH2+ IS 23 aluminium, forged Performance Power-to-weight ratio to DIN: 5.1 kg/kW Output per litre: 77.3/105.1 kW/hp Acceleration 0–100 km/h: 4.8 sec Top speed: 250 km/h Fuel Consumption Urban ltr/100 km 17.9 Extra-urban ltr/100 km 9.2 Composite ltr/100 km 12.4 CO2 g/km 295 Miscellaneous Emission standard EU4 1Weight of car in road trim (DIN) plus 75 kg for driver and luggage. 2May be increased under certain conditions. 3Electronically limited. [br][br]-=-=-=-=- 以下內容由 yafayu 在 2007年04月15日 02:34am 時新增 -=-=-=-=- 4公升炸出420匹馬力, 這顆引擎準備會是2008的Engine of the Year了!! 先來恭喜BMW吧! 再次創出新的紀錄 |
這些小零件的組成可以創造出那麼吸引人的動力....
期待NEW M3在台灣的身影.... :em15: :em15: |
台灣不知何時可以看到它的身影?
| 所有時間均為台北時間。現在的時間是 02:59 PM。 |
