E36 320 這個型號是幾年到幾年出產的?雙門喔!
如標題
E36好像沒有320
我的車就是E36 320的
數量可能比較少...國外很多........其實還有很多車型..會在一些國家才會出現.......
台灣的好像只有看過四門。
E36 320 在台灣的數量好像不多...
上一部就是E36 320 雙門的,我的是92年可變的,印象是91到98,這車台灣很少,但我還蠻喜歡與懷念的,當出也是衝著它的稀有度才買的,之後脫手也方便
e36 二門的320在當時,就只有歐規的車才有,美規沒出320的..
國外的話它從1991年一直到1997年都有在生產.. 台灣量比較少是因為當時的總代理除了接單訂車外,只有少量引進,每一批車只引進幾十輛..不像二門的318或325都有常備庫存量.. 所以當時買車,除了用訂車或者是剛好有現車可以買到二門的320,一般都是直接選有現車的二門的318或325 |
The BMW E36 is the third generation of the 3 Series compact executive cars produced by BMW. Development began in July 1981, with design being approved in the late '80s. It was introduced in late 1990 (as a 1991 model) for Europe and in April 1991 (as a 1992 model) for US and Canada. It was the successor to the E30 3 Series and was eventually replaced by the E46 3 Series in 1998, though E36 coupes were still produced for the 1999 model year.
320i 1,991 cc (1.991 L; 121.5 cu in) 6cyl DOHC 24V Petrol 150 PS (110 kW; 148 hp) @5900 rpm 190 N·m (140 lb·ft) @4700 rpm M50B20
M52B20 10.0 9.9 214 km/h (133 mph) 1992–1993 1993–1999 這是雙門的coupe |
| 所有時間均為台北時間。現在的時間是 08:21 PM。 |
