舊 2006-03-25, 11:26 AM   #1
xturtle
註冊日期: 2003-06-04
住址: 無塵室
文章: 1,056
車型: E91E46碗公E36ti
120d customer racing 245匹 九萬五千歐元
[這篇文章最後由xturtle在 2006/03/25 07:10pm 第 1 次編輯]
Technical specifications: <P>
Length: 4,227 mm <P>
Width: 1,845 mm <P>
Height: approx. 1,360 mm <P>
Wheelbase: 2,660 mm <P>
Vehicle weight: 1,135 kg (with driver) <P>
Chassis/body: unitary construction steel body <P>
Aero package: front apron, rear apron, CFRP front wings and rear flared wheel arches, rear diffusor <P>
Front axle: double-joint spring strut axle with adjustable anti-roll bar <P>
Rear axle: five-link axle with adjustable anti-roll bar <P>
BMBMW Corporate Communications Motorsport <P>
Shock absorbers: Sachs with adjustable compression and rebound <P>
Brake system front: 332mm steel discs with six-piston AP fixed callipers<P>
Brake system rear: 284mm steel discs with four-piston AP fixed callipers<P>
Wheels: aluminium rims, 9??x17?? BBS <P>
Seat: Recaro ProRacer HANS <P>
Engine <P>
Engine type: four-cylinder inline diesel
<P>
Displacement: 1,995 cc <P>
Peak torque 450 Nm at 3,000 rpm <P>
Peak output: approx. 245 bhp at approx. 4,200 rpm <P>
Max engine speed: 5,000 rpm <P>
Cylinder block: grey-cast <P>
Engine control: DDE6.0 <P>
Tank capacity / Fuel: 100 litres, diesell <P>
http://bmwblog.net/?p=62
xturtle 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 04:43 AM
