舊 2014-06-17, 02:26 AM   #1
moto925077
moto925077 的頭像
註冊日期: 2012-04-23
住址: 高雄-台南
車型: E39 525
請教變速箱故障碼
請教各位大哥們
我的變速箱出現
30 轉換器鎖止離合器嚴重打滑(p0740,p2761,p0741)
請問是變速箱哪裡出問題:L
moto925077 目前離線   回覆時引用此篇文章
舊 2014-06-17, 10:41 AM   #2
P0740 扭力轉換器閉鎖裝置故障
P2761 扭力轉換器的離合器壓力電磁閥控制線路斷路
P0741 扭力轉換器打滑
BMW原廠在2008/02有出SI 24 03 06的技術通報
SUBJECT
ZF 5HP19 Transmission - Diagnosis of EGS FC 048 (30 hex)
MODEL
E46: 323i, 325i, 330i with M52TU, M54, M56 and ZF 5HP19
E39: 525i, 530i with M54 and ZF 5HP19
E85: Z4 roadster 2.5, 3.0 with M54 and ZF 5HP19
SITUATION
"Service Engine Soon" is illuminated and fault code 048 "Converter lock-up excessive slip" (30 hex or P0741) is stored in the EGS transmission control module.
CAUSE
Possible cause: deterioration of the torque converter turbine shaft seal
PROCEDURE
Remove the torque converter. For the removal procedure, refer to Repair Manual RA24 40 002.
2. Drain the fluid out of the torque converter, and carefully inspect the turbine shaft seal (1) INSIDE THE BOTTOM OF THE TORQUE CONVERTER for signs of damage (cracks, splits, etc.).Helpful Hints:
3. Use a small flashlight to illuminate inside the bottom of the torque converter to examine the turbine shaft seal. The turbine seal is brownish orange in color and measures approximately 1" in diameter.
If evidence of seal deterioration is found, replace the torque converter.
Additionally, if the transmission fluid shows signs of deterioration ("dirty fluid"), the fluid should be replaced in conjunction with the fluid strainer. For the strainer replacement procedure, refer to Repair Manual RA24 31 151.
Refill and/or top off the fluid level according to Repair Manual RA 00 11 500, using ESSO ATF LT 71141 (P/N 83 22 9 407 807).
If after careful inspection it appears that the turbine seal is intact, contact Automatic Transmission Enhanced Technical Support (TeileClearing) for further diagnostic instructions. Submit the "regular technical support" PuMA case, referencing SI B24 03 06 in its title.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for the appropriate model applicable labor allowances.
Defect Code
24 40 02 61 00
Labor Operation
24 40 002
Main Work*
Replace torque converter
or
Labor Operation
+24 40 502
*Main Work:
Use this labor operation number when this is the only repair being performed, or if this is the main repair when performed along with other repairs at the same time. If this is not the main repair, refer to KSD for the associated (+) labor operation code.
舊 2014-06-17, 10:45 AM   #3
如果只有..
P0740 扭力轉換器閉鎖裝置故障
P0741 扭力轉換器打滑
那應該是那個技術通報的問題沒錯,一般是換扭力轉換器就好了!!
但現在多了一個..
就要去判斷,這個故障碼的發生前後順序了..
如果是先P0740 、P0741 才引發 P2761,那就扭力轉換器的問題!
但如果是先 P2761 才去引發P0740 、P0741 那就是電磁閥的問題了!
舊 2014-06-17, 06:23 PM   #4
moto925077
moto925077 的頭像
註冊日期: 2012-04-23
住址: 高雄-台南
車型: E39 525
故障碼顯示是先p0740,然後是p2761,最後是p0741
舊 2016-12-09, 07:19 PM   #5
paulsmith0519
註冊日期: 2016-09-13
文章: 28
車型: E39 530i 2002/07
請問各位先進,我也遇到同樣的狀況!
"30 轉換器鎖止離合器嚴重打滑(p0740,p2761,p0741)"
不曉得應該怎麼處理呢? 先謝謝各位
paulsmith0519 目前離線   回覆時引用此篇文章
舊 2016-12-10, 10:07 AM   #6
可愛松鼠子
可愛松鼠子 的頭像
註冊日期: 2012-05-01
文章: 64
樂大~很感謝你~
你的資訊實用又準確~
CCT有你真好> " <
可愛松鼠子 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 08:03 AM
