舊 2010-12-16, 05:15 PM   #1
chuan9538
註冊日期: 2010-11-15
車型: 530i
E60保養後歸零
請問有哪位達人知道E60保養後的歸零方法嗎?我從i-drive進去怎麼都找不到路徑,傷腦筋中.求救
chuan9538 目前離線   回覆時引用此篇文章
舊 2010-12-16, 05:21 PM   #2
毅誠
毅誠 的頭像
註冊日期: 2010-03-30
贊助: 2010、2011
我都給保養廠歸零
毅誠 目前離線   回覆時引用此篇文章
舊 2010-12-16, 06:00 PM   #3
tsaicl
tsaicl 的頭像
註冊日期: 2005-11-27
文章: 2,191
偷偷告訴你 不要跟別人說喔
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
tsaicl 目前離線   回覆時引用此篇文章
舊 2010-12-16, 08:23 PM   #4
chuan9538
註冊日期: 2010-11-15
車型: 530i
這這這............叫我怎麼去偷偷告訴別人啊
舊 2010-12-18, 12:28 AM   #5
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
保養歸零不在 i drive理
ctc667712s 目前離線   回覆時引用此篇文章
舊 2010-12-18, 11:53 PM   #6
蛋王
蛋王 的頭像
註冊日期: 2007-01-27
文章: 988
車型: .E92.E93.E60.E70.F10
google翻譯結果:
首先與點火開關上,將里程表里程表回零推一次。然後切換回再次關閉點火。 (我發現這一步是至關重要的,否則我不能進入“服務”菜單)。
現在您已經準備好要經過重置步驟如下:
1。點火開關(使電池,石油和駐車制動燈顯示),關鍵是準備啟動發動機 - 但並沒有真正啟動汽車。
2。按里程表復位按鈕 5至10秒,直到一個黃色三角形感嘆號的中心出現在頂部窗口之間的時鐘(如外界溫度 /時間或日期通常會出現) - 這是“服務”圖標。
3。鬆開里程表短暫再次按下按鈕立刻帶來了一個圖片的制動液符號(同我的那個驅動器,當你看著顯示在服務菜單)。
4。如果你想重置制動液間隔 2年,然後再繼續保持里程表按鈕,直到單詞“重置?”顯示在窗口底部的低。
5。鬆開按鈕快速,並將它推再次按住約 5 - 10秒,直到新的日期出現在視窗的下方。然後,您可以關閉點火開關和新的制動液日期將出現在服務菜單上的i -驅動器屏幕下次開機。
6。如果你要重置油,Microfilter或剎車片的指標,那麼你將需要遵循相同的順序為步驟 1和2段,但是當你到步驟 3,制動液圖標出現,只是釋放按鈕,再次按下和下一個服務項目將出現。
7。您可以繼續發布並按下按鈕,直到出現需要的服務項目圖標為一個你想復位。只要它然後按住按鈕,直到在單詞“重置?”再次出現在上面的步驟 4。一旦單詞“重置?”已經出現,你需要釋放按鈕快速拿在手裡再次約 5 - 10秒,直到它被替換為新的服務間隔的數字(按上述步驟 5)。
提示與技巧
重置之前,實際上任何東西,經過步驟 1,2和第6段,直到你熟悉(和肯定)你要復位。實際上,這幾次,記下在什麼順序的圖標出現在最初的“服務”圖標。
如果你碰巧按住按鈕太長針對一個項目你不想重置和“復位?”看來,只要把單獨的按鈕 10秒左右,它不會讓你重新設置的項目。 (或者只是在點火開關關閉,重新開始)。
有時,如果你還沒有釋放,再次按下按鈕速度不夠快,當你拿著它下來了德國技術寫作後會出現約 15 - 20秒的服務項目,而不是您所期望的圖標。 (如果這恰好發生在點火開關關閉並重新開始)。
一旦你知道什麼項目要復位和有信心的序列,然後給它一去。如果你猶豫在放鬆的同時按下按鈕,在任何時候,你將不得不回到起點,重新開始為“他是誰不願失去”。
這方法是不是跟e46一樣啊?
歡迎加入BMW 專屬FB社團https://www.facebook.com/groups/528333063916531/最新款BMW MINI專用診斷電腦一組售2500.家鉅工業有限公司堆高機.買賣.維修--電動.柴油都有.日本外匯中古車.公司負責人: 張益誠.電話0937550850.LINE ID:eggs-king
此篇文章於 2010-12-19 12:02 AM 被 蛋王 編輯。
蛋王 目前離線   回覆時引用此篇文章
舊 2010-12-21, 05:11 PM   #7
chuan9538
註冊日期: 2010-11-15
車型: 530i
我已經請維修廠處理好了,這樣比較省事,thanks大家
舊 2016-06-30, 02:08 PM   #8
楊帥
註冊日期: 2016-06-09
保養歸零過程如下:
1.鑰匙轉到第2段
2.按住儀表左側里程歸零鈕,直到出現保養項目
3.出現保養項目後,每按一次就會出現一項保養內容
4.選定你所希望保養的項目後,按住歸零鈕直到
出現"RESET ? "
5.放開歸零鈕在按住,保養里程會出現"------"符號
之後會寫出保養間隔里程
注意:進行歸零時,所有車門都須關閉
楊帥 目前離線   回覆時引用此篇文章
舊 2017-03-18, 07:10 PM   #9
qmopw
註冊日期: 2012-12-16
車型: 2010年E90 325 Lci
感謝分享啊
qmopw 目前離線   回覆時引用此篇文章
舊 2017-03-19, 03:47 AM   #10
andy315
andy315 的頭像
註冊日期: 2016-08-30
住址: 岡山
文章: 240
有一般機油保養歸零,如果是其他類,如火星塞..來另...有百分比倒數計算的,需插電腦復位,我這邊車廠是使用ISTA/D
andy315 目前離線   回覆時引用此篇文章
舊 2017-04-04, 08:51 AM   #11
Swingger
註冊日期: 2017-02-01
文章: 45
車型: E60 530i
感謝前輩達人們的分享~~
Swingger 目前離線   回覆時引用此篇文章
舊 2017-04-08, 02:44 PM   #12
393006
註冊日期: 2017-03-07
文章: 54
又上一課了感謝
393006 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 04:10 AM
