舊 2013-01-12, 12:15 PM   #1
jackyryu
jackyryu 的頭像
註冊日期: 2012-08-07
住址: 老家台南現居桃園
車型: E46 320i 2.2
問題 請問有前輩車友E46 2.2改裝成增壓車+手排的嗎?
單純只是好奇一問,我看國外針對BMW的改裝大廠好像也都針對2.8以上大排氣量的車子才有推出機增或是渦增的改裝套件,不知道是不是因為2.2改增壓車C/P值不大,能增加的馬力/扭力輸出有限?如果真有車友改過,那數值能提昇多少呢?
jackyryu 目前離線   回覆時引用此篇文章
舊 2013-01-17, 04:29 PM   #2
mclarengp
註冊日期: 2012-11-26
文章: 75
車型: X5
有看過ㄚ虎拍賣改裝後可比美M3
mclarengp 目前離線   回覆時引用此篇文章
舊 2013-01-17, 04:50 PM   #3
CTK1980
註冊日期: 2007-10-30
住址: TAIPEI
文章: 363
Models
Sub-Models
Years
MSRP
KO Price
Availability
E46
320 2.2
2001-2004
$6550.00
$6353.00
Usually In Stock
When experiencing an ESS BMW Supercharger you’ll get instantaneous power with a touch of class.
High quality construction
Featuring the advanced, high-speed ASA TM1-12 supercharger unit which combines the efficiency of a turbocharger with the drivability and smoothness of a supercharger. This is the only high-speed, turbo impeller supercharger unit on the market combining a durable, synchronized gear transmission with a innovative clutch system that completely disengages the supercharger unit below 1000RPM for 100% silent idle operation. This feature also improves idle and low speed cruising emissions and fuel consumption. As this unit is based on mechanical gears it does not suffer from the reliability issues that most other high-speed, ball-geared supercharger units are haunted by, it also removes the necessity for external supercharger oil cooling which reduces weight and installation time/complexity as well as providing a cleaner looking engine room.
Specifications:
  • Part number: 114-18
  • Boost pressure: 8 PSI
  • Horsepower: 270 DIN (Stock 170)
  • Torque: 300 NM (Stock 210)
  • 0 - 60: Man : 6.4 sec, Aut : 7.2 sec
  • Installation time: 8-10 hours
此篇文章於 2013-01-17 04:57 PM 被 CTK1980 編輯。
CTK1980 目前離線   回覆時引用此篇文章
舊 2013-01-17, 05:08 PM   #4
jackyryu
jackyryu 的頭像
註冊日期: 2012-08-07
住址: 老家台南現居桃園
車型: E46 320i 2.2
不錯
作者: CTK1980 查看文章
Models
Sub-Models
Years
MSRP
KO Price
Availability
E46
320 2.2
2001-2004
$6550.00
$6353.00
Usually In Stock
Specifications:
謝謝CTK1980大大提供的數據,看起來E46 2.2若是以不拓缸的原則下去改,所增加的頂多也是到E46 330i左右的水準,果真是C/P值不高呢~!
舊 2013-01-17, 06:04 PM   #5
豆乾
註冊日期: 2011-04-06
文章: 829
那是改裝廠保險的改吧.正常2.2用TD06-20G或18G.排測8CM的話.打個1公斤差不多M3的實力了.周邊在加強的話上到1.2以上.過4百因該不成問題了.
豆乾 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 07:53 PM
