舊 2013-02-25, 12:36 PM   #1
leonjacky
註冊日期: 2011-01-21
文章: 34
DIY 開啟 E60 隱藏的 Sport Mode
從外國網站,發現一條有關E60應有表現的標題,該文話所有E60原來除了有DS mode之外,還有一項名為 FDC的東西內藏著........
根據 BMW 網站:
Sport mode.Tune up: when sport mode is activated, engine output and driving dynamics take on sportier qualities, letting you enjoy your BMW's dynamic character at its peak.
Depending on which BMW model you drive, the sport mode can be activated by a touch of the "Sport" button on the central console. Immediately, your BMW feels even more dynamic: the electronic control units switch to sportier settings, making the engine more responsive and the suspension stiffer.
This increase in sports-style characteristics is accompanied by a reduction in powered assistance for the steering at low and medium RPMs for more direct and immediate steering, giving you an even closer sense of the character of the road.
In vehicles with automatic transmission or the Sequential Manual Gearbox (SMG), activating the sport mode (also known as Driving Dynamic Control) shortens gearshift times and makes the gearshift characteristic even more dynamic.FDC "Dynamic Driving Control (FDC) can be selected with the SPORT button in either automatic mode or manual mode. FDC is always deactivated when the engine is started.
When Dynamic Driving Control (FDC) is activated with the SPORT button, shift times for gear changes are reduced by the SMG control unit. In addition, in automatic mode the SMG only shifts into the next gear up at higher engine speeds. The DME unit adjusts the accelerator-pedal values. The engine responds quicker to changes in the accelerator pedal position. The system also switches "Servotronic" or "Active steering" option to a more sports-oriented characteristic. Steering and holding forces on the steering wheel are given more sporty settings."
見到有美鬼成功,亦參考過google translated的德國網站,其實好鬼簡單,兩條電線,插落中控下DTC果組野背後插的其中兩隻腳,short 一 short 就能啟動 Sport Mode,於是.......我.......
然後.......
嘩,個SPORT字真係出現,更加估佢唔到係,堂呔馬上變得很重,油門的反應快得很,好似變左另一隻馬,與DS mode有很大分別,在DS mode堂呔唔會變重,轉波特性也很不同,最神係在DS mode也可再加 Sport Mode, 要再慢慢試下。
最後用了小制做開關。
leonjacky 目前離線   回覆時引用此篇文章
舊 2013-02-25, 12:44 PM   #2
Mamuro
註冊日期: 2013-02-09
文章: 178
車型: E60 520D
真的還是假的,有那麼神嗎?回家要試一下看。
堂呔 --> 這2字什麼意思?
Mamuro 目前離線   回覆時引用此篇文章
舊 2013-02-25, 01:05 PM   #3
EDC79
註冊日期: 2012-08-28
住址: 新莊
文章: 189
車型: E39 518i
有這種東西,原廠寧可藏起來?為什麼?
如果真的叫出來之後具有這麼多好處,原廠為什麼要藏起來?
EDC79 目前離線   回覆時引用此篇文章
舊 2013-02-25, 01:52 PM   #4
leonjacky
註冊日期: 2011-01-21
文章: 34
作者: Mamuro 查看文章
堂呔 --> 這2字什麼意思?
steering wheel
舊 2013-02-25, 01:58 PM   #5
leonjacky
註冊日期: 2011-01-21
文章: 34
作者: EDC79 查看文章
有這種東西,原廠寧可藏起來?為什麼?
$$$$唄,原廠是真的有...
Item 8 - 61316922799, Auto Sport Switch
Item 12 - 51167059900 (right handed steering) Shift Bezel , with Sport Button cut-out
舊 2013-02-25, 02:18 PM   #6
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
作者: Mamuro 查看文章
堂呔 --> 這2字什麼意思?
方向盤:D
ctc667712s 目前離線   回覆時引用此篇文章
舊 2013-02-25, 02:51 PM   #7
staysher
staysher 的頭像
註冊日期: 2012-03-29
文章: 371
e60不錯喔 竟然還有sports mode可以玩.
staysher 目前離線   回覆時引用此篇文章
舊 2013-02-25, 02:58 PM   #8
Mamuro
註冊日期: 2013-02-09
文章: 178
車型: E60 520D
作者: leonjacky 查看文章
steering wheel
Tks~~~
舊 2013-02-25, 03:02 PM   #9
Mamuro
註冊日期: 2013-02-09
文章: 178
車型: E60 520D
E60的車主,直接做整套團購買原廠按鈕了吧~~~
舊 2013-02-25, 03:05 PM   #10
leonjacky
註冊日期: 2011-01-21
文章: 34
作者: Mamuro 查看文章
原廠的有點貴,around HK$2000!我用HK$15的,效果一樣的。
舊 2013-02-25, 03:09 PM   #11
阿堆
阿堆 的頭像
註冊日期: 2008-12-04
文章: 1,770
哪兩條是從裡面切換DS mode接點哪邊接出來的嗎??
阿堆 目前離線   回覆時引用此篇文章
舊 2013-02-25, 03:35 PM   #12
leonjacky
註冊日期: 2011-01-21
文章: 34
不是從DS Mode接出來的。DS mode 不能啟動FDC(Sport mode)也不會改變油門的反應。
是中控後插 X13938的8與10空位置,利用 one push button啟動或關閉。原廠方案還要接上9號空位置亮LED....
這是DS Mode加上 FDC
舊 2013-02-25, 03:46 PM   #13
阿堆
阿堆 的頭像
註冊日期: 2008-12-04
文章: 1,770
作者: leonjacky 查看文章
這是DS Mode加上 FDC
感謝解說啦~~
阿堆 目前離線   回覆時引用此篇文章
舊 2013-02-25, 03:52 PM   #14
LMing
LMing 的頭像
註冊日期: 2011-06-14
文章: 209
車型: F87 M2, F10 M5
這沒刷SAT軟體大概也沒啥差別,有SPORT的DS檔會寫S1-S5隨時跟你說你在哪檔,這還是要軟體支援
http://www.mobile01.com/topicdetail....5&p=1#39935760
LMing 目前離線   回覆時引用此篇文章
舊 2013-02-25, 04:12 PM   #15
staysher
staysher 的頭像
註冊日期: 2012-03-29
文章: 371
作者: LMing 查看文章
老大e87有SAT可以刷來玩嗎?? 是不是要搭配改方向盤+換檔撥片
舊 2013-02-25, 04:16 PM   #16
LMing
LMing 的頭像
註冊日期: 2011-06-14
文章: 209
車型: F87 M2, F10 M5
SAT只支援線傳.....後期得E92 DCT就有.......
舊 2013-02-25, 04:25 PM   #17
kevinshop
kevinshop 的頭像
註冊日期: 2008-06-04
文章: 598
車型: 08 E60 530I
E60小改款有增加SPORT鍵
http://www.intl-estate.com/
佳心海外置業網-您海外投資的好幫手!
kevinshop 目前離線   回覆時引用此篇文章
舊 2013-02-25, 04:29 PM   #18
leonjacky
註冊日期: 2011-01-21
文章: 34
作者: LMing 查看文章
FDC 是FDC....可以在Pre-Lci及 非SAT LCI型號啟動。LCI SAT 型號本身便加上了Sport button. FDC是無需刷軟件的,寶馬 E60 Training Course Manual 便有提及 "FDC"....04年 e60一出世便有了
當從Sport + DS,推+/- ,也會變成 Sport + M2-3....
舊 2013-02-25, 04:33 PM   #19
LMing
LMing 的頭像
註冊日期: 2011-06-14
文章: 209
車型: F87 M2, F10 M5
作者: leonjacky 查看文章
非LCI的小弟就不清楚了,謝謝解說,S1-S5只是在DS模式下,告訴你現在的SPORT檔位,手動也是寫M1-M5
舊 2013-02-25, 04:40 PM   #20
阿wei
註冊日期: 2005-07-09
住址: 台南或南投游走中
文章: 1,011
贊助: 2007
不知台灣哪裡有再代為安裝此功能的??
阿wei 目前離線   回覆時引用此篇文章
舊 2013-02-25, 04:44 PM   #21
leonjacky
註冊日期: 2011-01-21
文章: 34
DIY 只需30分鍾內呢。
舊 2013-02-25, 04:56 PM   #22
LMing
LMing 的頭像
註冊日期: 2011-06-14
文章: 209
車型: F87 M2, F10 M5
所以這是類似給PRE-LCI的SAT?
舊 2013-02-25, 05:04 PM   #23
leonjacky
註冊日期: 2011-01-21
文章: 34
不全對, LCI 非SAT版 也可有隱藏的FDC可DIY開啟。 LCI SAT 版上的 Sport button 便是FDC....以下是寶馬廠方介紹 SAT:
Power at your fingertips.
The six-speed sports automatic transmission
in the BMW 5 Series Sedan.
Take the power into your own hands with the six-speed sports automatic transmission. Choose automatic mode for supremely precise automatic gearshifts, or switch to manual mode for motorsports-style gear changes. Use the gearshift paddles mounted on the steering wheel or enjoy the precise feedback offered by the gear selector lever introduced exclusively for this special transmission. Pressing the Sports button makes the entire shift process even more dynamic.
所以FDC是FDC!
舊 2013-02-25, 05:04 PM   #24
guanyinma
guanyinma 的頭像
註冊日期: 2012-10-19
文章: 160
車型: 130i 850i
竟然有這種東西@@
guanyinma 目前離線   回覆時引用此篇文章
舊 2013-02-25, 05:30 PM   #25
staysher
staysher 的頭像
註冊日期: 2012-03-29
文章: 371
作者: LMing 查看文章
E87 LCI也已經是線傳了不是嗎?
舊 2013-02-25, 06:47 PM   #26
LMing
LMing 的頭像
註冊日期: 2011-06-14
文章: 209
車型: F87 M2, F10 M5
E87沒有線傳~
舊 2013-02-25, 07:08 PM   #27
小黑黑
註冊日期: 2006-12-28
文章: 162
車型: e53 x5
雖然看不懂,不過感覺好厲害的樣子.....
小黑黑 目前離線   回覆時引用此篇文章
舊 2013-02-25, 08:05 PM   #28
guanyinma
guanyinma 的頭像
註冊日期: 2012-10-19
文章: 160
車型: 130i 850i
E87沒有〜
舊 2013-02-25, 08:06 PM   #29
tracyhsiao9
tracyhsiao9 的頭像
註冊日期: 2011-03-24
文章: 100
車型: M235i, 520D
作者: 小黑黑 查看文章
不知有沒有店家有研究???雖然看不太懂~~但很想試試看~~~
tracyhsiao9 目前離線   回覆時引用此篇文章
舊 2013-02-25, 08:07 PM   #30
黑色影子
黑色影子 的頭像
註冊日期: 2011-08-18
文章: 52
車型: E60-523i,,F11-520d
大大請問一下有分年份嗎
黑色影子 目前離線   回覆時引用此篇文章
舊 2013-02-25, 08:15 PM   #31
leonjacky
註冊日期: 2011-01-21
文章: 34
E60任何年份皆可
舊 2013-02-25, 08:26 PM   #32
leonjacky
註冊日期: 2011-01-21
文章: 34
開中控
找到DTC背部中間的插制,用兩條電線,接上一個one push buttom,禮成。
舊 2013-02-25, 08:32 PM   #33
chyencha
chyencha 的頭像
註冊日期: 2011-06-23
文章: 120
贊助: 2013
謝謝大大的分享~
友誼萬歲~~
chyencha 目前離線   回覆時引用此篇文章
舊 2013-02-25, 09:21 PM   #34
毅誠
毅誠 的頭像
註冊日期: 2010-03-30
贊助: 2010、2011
毅誠 目前離線   回覆時引用此篇文章
舊 2013-02-25, 09:27 PM   #35
power龍
power龍 的頭像
註冊日期: 2010-06-26
住址: 台南~高雄~里港
文章: 115
哈哈~明天就訂料...!!
謝謝.............
power龍 目前離線   回覆時引用此篇文章
舊 2013-02-25, 09:39 PM   #36
leonjacky
註冊日期: 2011-01-21
文章: 34
如屬lci款,插位有所不同,要用中控後的7及9空位。
舊 2013-02-25, 10:14 PM   #37
Alan
註冊日期: 2002-10-03
住址: 臺灣臺中
可以請教一下DTC排線組在哪邊? 號碼怎麼看?? 謝謝!
Alan 目前離線   回覆時引用此篇文章
舊 2013-02-25, 10:30 PM   #38
毅誠
毅誠 的頭像
註冊日期: 2010-03-30
贊助: 2010、2011
作者: power龍 查看文章
哈哈~明天就訂料...!!
謝謝.............
你改很大勒
順便幫我訂一個
毅誠 目前離線   回覆時引用此篇文章
舊 2013-02-25, 10:44 PM   #39
林小銘
林小銘 的頭像
註冊日期: 2012-12-13
BMW實在是太深不可測了,Leon大感謝你的分享,長知識了!
--------------------------------------------------------------------------------------小弟從事重型機車業,車友有經過小店可以進來坐坐LDS,有關重車的相關事宜也可以找我喔~~
林小銘 目前離線   回覆時引用此篇文章
舊 2013-02-25, 11:16 PM   #40
阿wei
註冊日期: 2005-07-09
住址: 台南或南投游走中
文章: 1,011
贊助: 2007
作者: power龍 查看文章
哈哈~明天就訂料...!!
謝謝.............
如果用好!施工順利也幚我訂一組!幫我用
阿wei 目前離線   回覆時引用此篇文章
舊 2013-02-25, 11:31 PM   #41
power龍
power龍 的頭像
註冊日期: 2010-06-26
住址: 台南~高雄~里港
文章: 115
作者: 毅誠 查看文章
你改很大勒
順便幫我訂一個
你改最大啦...........中區532一哥!!!
舊 2013-02-25, 11:32 PM   #42
power龍
power龍 的頭像
註冊日期: 2010-06-26
住址: 台南~高雄~里港
文章: 115
作者: 阿wei 查看文章
如果用好!施工順利也幚我訂一組!幫我用
哈哈....請問您是...??
舊 2013-02-26, 12:41 AM   #43
mini03
註冊日期: 2012-03-30
車型: e60
感謝大大分享!!
小弟也成功開啟!!
但小弟遇到幾個問題想請教大大
1.打R檔時是否SPORT自動關閉,因為小弟完工測試時,打R檔儀表上SPORT的字樣就消失了
2.不知道是否開關的問題,因為小弟買錯開關,買到有段的開關,後來把開關的卡榫剪斷改成無段,造成行駛中儀表上SPORT燈會開開關關的
3.小弟的車子為05年的520I,開SPORT MODE我卻沒感覺有何變化,會不會是車子沒有支援FDC,還是小弟神經太大條?
4.小弟有裝電子油門加速器會不會影響?
ps.如果大大們要訂料我能不能加入,小弟也有興趣,不然依目前的開關樣式....,怕如果有機會載妹妹的時候會有點掉漆
感謝各位大大耐心的看完!!
謝謝大家!!
76031_550253281661194_1960997468_n.jpg   11127_550253314994524_1978757209_n.jpg
mini03 目前離線   回覆時引用此篇文章
舊 2013-02-26, 08:40 AM   #44
leonjacky
註冊日期: 2011-01-21
文章: 34
Button要使用"一按開"的,不要長期接通的那種。
Sport會在關車後自動關上,關上後要重啟。一般我在街道上才開sport mode,泊車之類,我會關上,倒車會否關上,試了再報告。
呔盤會否變重,綜合了報告,有active steering的,沒有改變,試過幫一架04年520i開啟,呔盤也沒改變,只有加速及排段變快。
我建議你把電子油門拿下,再感受一下,應該會感受到油門及排段的變化。我的寶馬維修員說電子油門不是好東西。
所有E60皆有FDC的。
舊 2013-02-26, 01:03 PM   #45
毅誠
毅誠 的頭像
註冊日期: 2010-03-30
贊助: 2010、2011
作者: power龍 查看文章
我那有
毅誠 目前離線   回覆時引用此篇文章
舊 2013-02-26, 01:21 PM   #46
mini03
註冊日期: 2012-03-30
車型: e60
感謝leonjacky大大!!
小弟問題已解除
1.打R檔,SPORT確定會關閉
2.開關的問題,也已經處理好了,因為我買的開關裡面銅片沒有固定,會在行車時因車體震動造成銅片接觸
3.小弟後來把電子油門加速器關掉測試油門反應確實有差
感謝大大
讓小弟受益良多
最後附上各檔位儀表板上的顯示
謝謝各位大大
舊 2013-02-26, 01:23 PM   #47
Mamuro
註冊日期: 2013-02-09
文章: 178
車型: E60 520D
在那裡可以幫改的再PM一下。
舊 2013-02-26, 03:01 PM   #48
leonjacky
註冊日期: 2011-01-21
文章: 34
作者: mini03 查看文章
感謝leonjacky大大!!
小弟問題已解除
1.打R檔,SPORT確定會關閉
感謝大大
讓小弟受益良多
最後附上各檔位儀表板上的顯示
謝謝各位大大
過癮吧。方向盤沒有變化嗎?
舊 2013-02-26, 03:40 PM   #49
power龍
power龍 的頭像
註冊日期: 2010-06-26
住址: 台南~高雄~里港
文章: 115
作者: 毅誠 查看文章
我那有
哪沒有!你發誓……
今天料訂了……哈!
舊 2013-02-26, 05:05 PM   #50
mini03
註冊日期: 2012-03-30
車型: e60
作者: leonjacky 查看文章
過癮吧。方向盤沒有變化嗎?
過癮!!!
可是方向盤沒有變化
是我感覺麻木嗎?!
所有時間均為台北時間。現在的時間是 12:32 AM
