舊 2014-10-24, 09:07 PM   #1
簡嘉弟
簡嘉弟 的頭像
註冊日期: 2014-10-20
文章: 79
車型: E87 120i
請教:DIY更換ATF方向機油的步驟
小弟想要自己更換方向機油,聽說是要用循環的方式更換,而且一次需要兩瓶油,請教各位,何謂"循環方式"以及更換步驟?還有我的方機油壺蓋,有標示使用ATF油,那我可以使用CHF 11S的油嗎?麻煩指導一下,謝謝.
簡嘉弟 目前離線   回覆時引用此篇文章
舊 2014-10-24, 09:17 PM   #2
小所長
小所長 的頭像
註冊日期: 2009-05-18
文章: 394
簡要說明
熱車後...
打左打右抽油壺...
補新油打左打右...
反覆數次至油色清澈...
PENTOSIN CHF11S可以和PENTOSIN CHF202混合使用...
但不可和PENTOSIN CHF7.1或其他任何液压油混合使用...
所以一般ATF的油壺應該不可以加入CHF11S...
PENTOSIN CHF11S is compatible with PENTOSIN CHF202. However, CHF11S and CHF202 should NOT be mixed with PENTOSIN CHF7.1 or any other hydraulic fluids. (Pentosin CHF7.1 is a non-synthetic, mineral based fluid, while CHF11S and CHF202 are synthetic oil based). CHF11S and CHF202 are fully compatible and mixable. However, PENTOSIN CHF fluids should NOT be mixed with ATF fluids. Use of ATF fluids where CHF fluid is required will cause damage to seals and other components of the hydraulic system. Conversely, use of CHF fluids where ATF is specified is also inappropriate and will ultimately cause system damage. Therefore, please confirm that this is the correct fluid for the vehicle before use. The required fluid will usually be specified in your owner's manual, and on the fluid reservoir cap. If you are uncertain, feel free to email or call us (209) 951-3761 for assistance.
小所長 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 02:16 AM
