舊 2005-05-11, 10:03 PM   #1
lii63
註冊日期: 2004-10-19
文章: 99
[求助]裂開了
E46後面固定牛擔的地方裂開了,請問各位就直接回原廠修嗎?還是?大概要修多久花多少?快吐血了
lii63 目前離線   回覆時引用此篇文章
舊 2005-05-11, 10:29 PM   #2
[求助]裂開了
找版金的焊接強化一下應該就可以了吧!
舊 2005-05-11, 10:42 PM   #3
xturtle
註冊日期: 2003-06-04
住址: 無塵室
文章: 1,056
車型: E91E46碗公E36ti
[求助]裂開了
來一組
E46 Rear Subframe Reinforcement Kit<P>
The E46 rear driveline and suspension are very similar to that of the E36. An unfortunate side effect of this is that the E46 also shares
some of the same problems as the E36. One of these problems is the rear mounting points for the subframe, which can rip out from
their spots in the sheet metal (see figure 1). This happens because the rear differential transmits the torsional load from the engine
through the subframe, then into the chassis. This constant loading and unloading weakens the sheet metal and causes it to fatigue and
separate from the chassis. BMW tried to fix this problem in the E46 by placing a cross member on the front two mounting points of
the subframe. This cross member keeps the front mounting points from having problems by placing the bushing and the stud in
double-sheer, thus reducing the twisting action on the sheet metal. The unfortunate side effect of this is that the load from the front of
the subframe now gets transmitted to the left rear of the subframe. This is where we have seen many failures of the chassis on low
mileage street cars and race cars.
This product reinforces the chassis sheet metal at the subframe mounting points. We do this by thickening the metal and distributing
the load over a larger area. This kit will save time when repairing the chassis, and is also strongly recommended as a preventative
maintenance item.
xturtle 目前離線   回覆時引用此篇文章
舊 2005-05-11, 10:46 PM   #4
lii63
註冊日期: 2004-10-19
文章: 99
[求助]裂開了
看沒有啦,你也付個圖翻譯一下唄
舊 2005-05-19, 08:24 AM   #5
TOMMY77777
註冊日期: 2005-05-03
文章: 442
[求助]裂開了
他大概覺得所有的人學歷都是一樣高.
TOMMY77777 目前離線   回覆時引用此篇文章
舊 2005-05-19, 06:03 PM   #6
rolf
註冊日期: 2003-04-21
文章: 665
[求助]裂開了
E46後車架補強內襯套件
E46的後方懸吊系統比起E36來的小很多,大部分的E46都有一些遺傳自E36通病,其中一個問題就是後方避震器上座很容易與後方的鈑件撕裂,原因是後差速器把引擎傳來的扭力傳到副車架,再分散到底盤上
然而持續不斷上下波動的扭力(加減速)降會導致底盤上的鈑件產生扭曲與變形
BMW曾經嘗試解決這個問題,在鈑件上追加一組x型結構連接前方兩個避震器上座,並將前方避震器上座採用雙層版件內夾緩衝材,而這組x型結構可以將這些惡性的應力傳輸到左側後方的車架上
這個有不少設計瑕疵的車架應用在低里程數的道路車與賽車上
這項產品可以加強避陣器上座,我們使用增厚的鈑件僵硬力分布在更廣的鈑件區域上
這組套件可以解省您花費在底盤修護的費用,建議將它列為預防性的保養項目
翻的不好還請見諒!
龜先生~您嘛幫幫忙~介紹東西也要傳圖跟中譯阿~不然也附上連結吧~這樣誰看的懂阿?
rolf 目前離線   回覆時引用此篇文章
舊 2005-05-19, 06:30 PM   #7
立緯
註冊日期: 2004-09-23
文章: 1,156
[求助]裂開了
那有沒有E36ㄉ啊??
立緯 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 07:07 PM
