舊 2005-09-14, 10:15 AM   #1
e46bimmer
註冊日期: 2003-06-08
住址: Los Angeles
文章: 283
E46-OBC 隱藏功能
E46的OBC(on board computer)其實有很多隱藏的功能沒有顯示出來...
大家有空可以試試看 :em25:
P.S 看英文可以吧 <br>
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to On position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following functions
BMW E46 On-Board Computer (OBC) Hidden Codes(example description)
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Acticates the gauge drivers, indicators and LEDs to confirm function
3 SI Data 3.0 1098 Used fuel in litres since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolent/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-value Hex code
8.1 26C33C+ ADC values HG left/HG right
8.2 0000 ADC value brake degradation sensor (000=o.k.)
8.3 18C ADC value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+ ? 9.2 074_78+ ? 9.3 0011+ ? 10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used
21 Software Reset; reset OBC settings
00 End of test
e46bimmer 目前離線   回覆時引用此篇文章
舊 2005-09-15, 01:27 PM   #2
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
E46-OBC 隱藏功能
這個很好用,大力推薦給大家!e38/e39e46/e53適用!
ctc667712s 目前離線   回覆時引用此篇文章
舊 2005-09-15, 01:51 PM   #3
馬沙
註冊日期: 2004-04-26
文章: 79
E46-OBC 隱藏功能
我找個個找很久了 謝謝大大熱心提供........
馬沙 目前離線   回覆時引用此篇文章
舊 2005-09-15, 01:51 PM   #4
揪尼
註冊日期: 2003-11-03
住址: 外太空
文章: 2,146
E46-OBC 隱藏功能
謝謝分享......................
揪尼 目前離線   回覆時引用此篇文章
舊 2005-09-19, 02:42 PM   #5
naimalajumbo
naimalajumbo 的頭像
註冊日期: 2005-05-18
住址: 桃園的小Q
文章: 3,542
E46-OBC 隱藏功能
真是太實用了啦~~~
只是.....
有沒有中文翻譯的呀~~~ :em06:
英文不太好~~~呵~~~
naimalajumbo 目前離線   回覆時引用此篇文章
舊 2005-10-01, 11:14 PM   #6
NOS-阿志
NOS-阿志 的頭像
註冊日期: 2004-11-14
住址: FB:超跑勁駒世界
文章: 2,450
車型: Aeroquip E39
E46-OBC 隱藏功能
http://babelfish.altavista.com/babelfish/tr
英翻中
NOS-阿志 目前離線   回覆時引用此篇文章
舊 2005-10-02, 01:26 AM   #7
台西虱目魚
台西虱目魚 的頭像
註冊日期: 2004-11-28
住址: 台西海邊
文章: 1,762
贊助: 2006、2007、2011
E46-OBC 隱藏功能
1.按住里程歸零鍵超過五秒。
2.或點火開關關時按住里程歸零鍵,同時將點火開關開到點火第一段(R段),放開里程歸零鍵。此時,儀表板內原顯示里程數的位置會顯示 tESt 01. 表示已成功地進入自我診斷測試功能。
3.進入自我診斷測試功能後呼叫內部資訊。~~~~~~這個您們應該較感興趣
當 tESt 01. 出現時.
1秒內再按里程歸零鍵,則進入主目錄 tESt 02.
______________________________________________________
當 tESt 01. 出現時
不按里程歸零鍵,則進入其子目錄 XXXX 1.0
按里程歸零鍵,則進入其子目錄第二項內容 XXXX 1.1
以此類推
當進入子目錄後欲回到主目錄時操作如下
XXXX 1.1 按住里程歸零鍵,超過一秒後放開 eESt 02.
以此類推
功能一覽
主目錄 子目錄 代表意義
01 1.0 車身號碼
1.1 車體號碼
1.2 零件號碼
1.3 代碼/診斷碼/BUS碼
1.4 製造號碼
1.5 硬/軟體號碼
1.6 缸數噴油狀態
02 儀表板功能自我測試
03 3.0 保養指示器的設定值(油量)
3.1 大保養的設定值(天數)
04 4.0 每千公里平均耗油量目前的計算值
4.1 每小時平均耗油量
05 5.0 已行駛里程的平均耗油量
5.1 已行駛的里程數
06 6.0 左、右油箱的油量
6.1 總油箱的平均油量數
6.2 總油箱的油量數及感應器的狀態
07 7.0 目前引擎水溫
7.1 目前外界溫度
7.2 目前引擎轉速
7.3 目前車速
08 8.0 原廠輸入的進位值
09 9.0 電瓶電壓
10 10.0 國家碼
11 11.0 儀表板密碼
12 12.0 空白
13 13.0 蜂鳴器測試
14 14.0 故障記憶(000000表無故障記憶)
15 空白
16 空白
17 空白
18 空白
19 19.0 開啟或關閉測試功能
20 20.0 平均耗油量修正值
21 21.0 儀表板軟體重新歸零
PS:主目錄19可開啟或關閉測試功能,01、02、21不受主目錄19控制
以上僅供參考
若有錯誤敬請多多指正 :em15:
-=-=-=-=-=>以上轉貼一位達人的作品.................
台西虱目魚 目前離線   回覆時引用此篇文章
舊 2005-10-02, 01:30 AM   #8
阿儒
阿儒 的頭像
註冊日期: 2002-10-02
住址: 臺南
文章: 2,355
E46-OBC 隱藏功能
哇!幸福啦!
阿儒 目前離線   回覆時引用此篇文章
舊 2005-10-02, 03:29 PM   #9
勝綸
勝綸 的頭像
註冊日期: 2005-08-28
住址: 凱薩皇宮(平鎮區)
文章: 686
車型: BMW F10 528i
E46-OBC 隱藏功能
這個真的要掌聲鼓勵一下.....
勝綸 目前離線   回覆時引用此篇文章
舊 2005-10-02, 08:20 PM   #10
小象
小象 的頭像
註冊日期: 2003-07-13
文章: 2,007
車型: E38 730I
E46-OBC 隱藏功能
下面引用由台西虱目魚2005/10/02 01:26am 發表的內容:
1.按住里程歸零鍵超過五秒。
2.或點火開關關時按住里程歸零鍵,同時將點火開關開到點火第一段(R段),放開里程歸零鍵。此時,儀表板內原顯示里程數的位置會顯示 tESt 01. 表示已成功地進入自我診斷測試功 ...
我還以為你的成度這麼高耶
原本想誇一下
原來是轉貼一位達人的作品.................
小象 目前離線   回覆時引用此篇文章
舊 2005-10-04, 08:43 PM   #11
台西虱目魚
台西虱目魚 的頭像
註冊日期: 2004-11-28
住址: 台西海邊
文章: 1,762
贊助: 2006、2007、2011
E46-OBC 隱藏功能
下面引用由小象2005/10/02 08:20pm 發表的內容:
我還以為你的成度這麼高耶
原本想誇一下
:em12: :em12: :em12: 找文章也很辛苦ㄟ :em16:
舊 2005-10-24, 01:00 AM   #12
jan1976
註冊日期: 2004-11-18
住址: 台北-新竹
文章: 728
E46-OBC 隱藏功能
jan1976 目前離線   回覆時引用此篇文章
舊 2005-10-24, 05:08 AM   #13
fernand
註冊日期: 2003-01-09
住址: 臺灣桃園
文章: 769
E46-OBC 隱藏功能
受益無窮, 感謝
fernand 目前離線   回覆時引用此篇文章
舊 2005-11-04, 04:28 PM   #14
TOMMY77777
註冊日期: 2005-05-03
文章: 442
E46-OBC 隱藏功能
讚~~~~讚~~~~~~~讚~~~~~~~~~~~~~~~~~~~~~~~
TOMMY77777 目前離線   回覆時引用此篇文章
舊 2006-03-29, 09:20 PM   #15
qk0948
註冊日期: 2005-03-28
文章: 507
E46-OBC 隱藏功能
下面引用由naimalajumbo2005/09/19 02:42pm 發表的內容:
真是太實用了啦~~~
只是.....
有沒有中文翻譯的呀~~~
英文不太好~~~呵~~~
指示訪問被隱藏的OBC 功能︰ 1.保持旅行被在在位置上把點火鑰匙轉向時重新安放
2.OBC 應該顯示"測試"
3.使用旅行把開的全部特徵的鎖的19.0 調節給選擇功能
3.等展示"離開"顯示
4.壓下旅行把秒調節給1/4並且釋放它
5.沒有延遲壓重新安放的旅行幾次選擇下列功能之一
寶馬E46 機載計算機(OBC)隱藏代碼(例子描述)
1台小汽車發動機和群數據
1.0 46nnn 底盤nr/VIN 順序號(上次5位數字)
1.1 4nnn K 號1.2 690236群部分1.3 045210個編碼的(04)/ 診斷(52)/公共汽車索引 ( 10 )
1.4 1200 周(12)/ 年的製造 ( 2000 )
1.5 09 _ 160 硬體(09)和群的軟體(16.0)
1.6並非使用的1.7 04 _ _ 44罐頭版本(04)KI 修正索引 ( 44 )
2(測試)群系統測試 - Acticates 確認功能的計量器驅動器,指標和LEDs
從上次SI(業務檢查)起的3個SI 數據3.0種1098使用的以公升計量的燃料
3.1 0231 定期檢查天; 天(從上次SI起)過去
4 瞬間的消耗
4.0 0145 + 立即的燃料消耗-0145 = 14.5公升/ 100 公里
4.1 0018 立即的燃料消耗-0018 = 1.8 l/Hour
去的5段距離消耗
5.0 082平均英里數; 082 = 8.2公升/ 100 公里
5.1 0536 Calc。 要給加油的公里(要去的瞬間的距離)
公升6個燃料水準傳感器輸入端
平均的6.0 109330 +燃料水準; 被離開的一半傳感器輸入端= 10.9公升; 右邊的傳感器輸入端= 33.0公升
總油箱水準平均的6.1 0439 +; vlgs 6.0︰10.9 +33.0 = 43.9公升
6.2 0442 + 注明價值(44.2)和油箱階段
7溫度和速度
Coolent/Engine 7.0 021 + 7.1 130溫度(2.1 C)周遭/在溫度外邊 - chg 遇見5 pts。 125/130/135
7.2 + 發動機速度/ 當今的RPMs 1 /分
公里/小時7.3 + 車輛速度/ 當今的速度
以六角形的形式的8輸入值
8.0 1d 0 +系統電壓ADC 估價六角形的代碼
8.1 26C 33C + ADC 估價離開的汞/右的汞
8.2 0000 ADC 估價剎車墮落傳感器(000 = o.k.)
在溫度9電池9.0 140電池電壓-140外邊的8.3 18 C ADC價值 = UB 14.0 v 9.1 242013 +嗎? 9.2 074 _ 78 +嗎? 9.3 0011 +嗎? 10被不使用
11被不使用
12被不使用
13面GonG鑼測試
14不使用15 地位串輸入/輸出港口(一點兒代碼)低的0 =; 1 =高
第1帶子的接觸,安全帶固定= 0; 2)點火鎖接觸,鑰匙插入= 0; 3)門接觸,門打開= 0; 4)鐘鈕扣壓= 0; 5)0 = 調節的SI,適合調節0 =; 6)EGS 輸送失敗= 0
地位數字化產量(一點兒)不活潑的0 =,積極的1 =
1)Gong產量; 2)剎車警告燈; 3)低的燃料警告燈; 4)埃加燈; 5)安全帶燈; 6)操作小圓點
16被不使用
17被不使用
18被不使用
19鎖地位; 在射程內開功能的鎖 3-18
在L 上/ 離L 19.0開鎖︰ 當"離L"時,按鍵不使用的20
重新安放的21軟體; 調節OBC 底座
試驗的00個末端
qk0948 目前離線   回覆時引用此篇文章
舊 2006-03-31, 11:00 PM   #16
tsaicl
tsaicl 的頭像
註冊日期: 2005-11-27
文章: 2,191
E46-OBC 隱藏功能
主目錄 子目錄 代表意義x{JWt&
01 1.0 車身號碼:/ EuE
1.1 車體號碼2
1.2 零件號碼[0{
1.3 代碼/診斷碼/BUS碼"*4
1.4 製造號碼34
1.5 硬/軟體號碼3
1.6 缸數噴油狀態pn+';N
02 儀表板功能自我測試b!}6
03 3.0 保養指示器的設定值(油量)F%{W
3.1 大保養的設定值(天數) 04 4.0 每千公里平均耗油量目前的計算值c<.
4.1 每小時平均耗油量ld6m
05 5.0 已行駛里程的平均耗油量LpD
5.1 已行駛的里程數V+\=3
06 6.0 左、右油箱的油量|4m
6.1 總油箱的平均油量數cx
6.2 總油箱的油量數及感應器的狀態sY
07 7.0 目前引擎水溫 7.1 目前外界溫度n6$\z
7.2 目前引擎轉速,X2FE
7.3 目前車速L
08 8.0 原廠輸入的進位值M+
09 9.0 電瓶電壓CTd
10 10.0 國家碼Ea7ql,
11 11.0 儀表板密碼M*R/O
12 12.0 空白)2P,
13 13.0 蜂鳴器測試R^8pJM
14 14.0 故障記憶(000000表無故障記憶)Lj\6
15 空白 Ei^LG
16 空白<T~"
17 空白n+M
18 空白{O5}
19 19.0 開啟或關閉測試功能%5.
20 20.0 平均耗油量修正值y8fh
21 21.0 儀表板軟體重新歸零!#E
&copy;BMWCCT台灣車主聯誼會 --   ';h
PS:主目錄19可開啟或關閉測試功能,01、02、21不受主目錄19控制g$/i
以上僅供參考
tsaicl 目前離線   回覆時引用此篇文章
舊 2006-04-03, 10:36 AM   #17
新手E38
註冊日期: 2006-03-20
文章: 63
E46-OBC 隱藏功能
為什麼我從03開始都是出現LOCK....??????[br][br]-=-=-=-=- 以下內容由 新手E382006年04月06日 06:13pm 時新增 -=-=-=-=-
有人能幫我嗎??????
新手E38 目前離線   回覆時引用此篇文章
舊 2006-04-03, 11:50 AM   #18
naimalajumbo
naimalajumbo 的頭像
註冊日期: 2005-05-18
住址: 桃園的小Q
文章: 3,542
E46-OBC 隱藏功能
1.按住里程歸零鍵超過五秒。
:em18: :em18: 真是嘉惠眾家E46車友....
太實用的資訊囉~~ :em03:
舊 2006-04-03, 11:28 PM   #19
CHS6015
註冊日期: 2006-03-06
文章: 119
E46-OBC 隱藏功能
請問有E34的嗎? 感恩!!
CHS6015 目前離線   回覆時引用此篇文章
舊 2006-04-03, 11:59 PM   #20
美麗島
註冊日期: 2006-01-07
E46-OBC 隱藏功能
實在是太感謝了.這麼詳細. :em04: :em04: :em04:
美麗島 目前離線   回覆時引用此篇文章
舊 2006-04-29, 04:35 AM   #21
sars8878
註冊日期: 2006-04-23
住址: 新北市的故鄉
文章: 446
E46-OBC 隱藏功能
不錯不錯.......感恩了
sars8878 目前離線   回覆時引用此篇文章
舊 2006-11-02, 11:48 PM   #22
0932774400
註冊日期: 2005-12-30
E46-OBC 隱藏功能
感謝前人種樹後人乘涼!!!!
0932774400 目前離線   回覆時引用此篇文章
舊 2006-11-03, 10:39 PM   #23
miracle
註冊日期: 2005-09-24
E46-OBC 隱藏功能
感恩ㄋㄟ
miracle 目前離線   回覆時引用此篇文章
舊 2006-11-04, 09:23 AM   #24
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
E46-OBC 隱藏功能
下面引用由新手E382006/04/03 10:36am 發表的內容:
為什麼我從03開始都是出現LOCK....??????-=-=-=-=- 以下內容由 新手E38 在 2006年04月06日 06:13pm 時新增 -=-=-=-=-
有人能幫我嗎??????
樓上的都寫了,你都不注意喔!
PS:主目錄19可開啟或關閉測試功能,01、02、21不受主目錄19控制[br][br]-=-=-=-=- 以下內容由 ctc667712s2006年11月04日 09:25am 時新增 -=-=-=-=-
請至功能19解開!
舊 2006-11-28, 09:11 AM   #25
hztwai
註冊日期: 2004-05-13
文章: 285
E46-OBC 隱藏功能
我的是E46
為什麼沒發車的情況下1和2可以進去
其他的3-21都是一跳到?.0就馬上跳出來了阿?
hztwai 目前離線   回覆時引用此篇文章
舊 2006-12-06, 01:50 AM   #26
言言的爸
註冊日期: 2004-07-28
文章: 688
車型: E92 M318
E46-OBC 隱藏功能
1.按住里程歸零鍵超過五秒。
這篇偶怎好熟悉低感覺呢 :em11: :em11:
言言的爸 目前離線   回覆時引用此篇文章
舊 2006-12-06, 10:05 PM   #27
Montblanc
註冊日期: 2006-11-29
文章: 311
E46-OBC 隱藏功能
下面引用由言言的爸2006/12/06 01:50am 發表的內容:
這篇偶怎好熟悉低感覺呢
你就是那個達人ㄚ.................瑋....
Montblanc 目前離線   回覆時引用此篇文章
舊 2006-12-06, 11:55 PM   #28
NOS-阿志
NOS-阿志 的頭像
註冊日期: 2004-11-14
住址: FB:超跑勁駒世界
文章: 2,450
車型: Aeroquip E39
E46-OBC 隱藏功能
下面引用由Montblanc2006/12/07 06:05am 發表的內容:
:em01: :em01: 被發現囉 :em01:
舊 2006-12-07, 12:19 AM   #29
台西虱目魚
台西虱目魚 的頭像
註冊日期: 2004-11-28
住址: 台西海邊
文章: 1,762
贊助: 2006、2007、2011
E46-OBC 隱藏功能
這篇偶怎好熟悉低感覺呢
你已經脫離e39,,快去改裝你的e46,,然後繼續累積經驗.嘉惠車友,繼續當改裝白老鼠!!!達人~~~~~~~~~~~~~瑋 :em01:
舊 2006-12-07, 02:39 AM   #30
言言的爸
註冊日期: 2004-07-28
文章: 688
車型: E92 M318
E46-OBC 隱藏功能
下面引用由台西虱目魚2006/12/07 00:19am 發表的內容:
下面引用由NOS-阿志2006/12/06 11:55pm 發表的內容:
被發現囉
您們喔 :em23: :em23: :em23:
Montblanc素???? :em14: :em14: 中文如何稱呼呀 :em14:
言言的爸 目前離線   回覆時引用此篇文章
舊 2006-12-11, 01:33 PM   #31
黑皮
註冊日期: 2006-10-24
住址: keelung
文章: 89
車型: F25
E46-OBC 隱藏功能
真實用的文章!受用了~~![br][br]-=-=-=-=- 以下內容由 黑皮2006年12月13日 11:35am 時新增 -=-=-=-=-
只有e46適用嗎!e38好像不一樣厚!!
黑皮 目前離線   回覆時引用此篇文章
舊 2006-12-13, 08:44 AM   #32
大頭呆
註冊日期: 2006-06-10
E46-OBC 隱藏功能
太屌了~~~高手
大頭呆 目前離線   回覆時引用此篇文章
舊 2007-08-06, 10:09 PM   #33
身心馳放
身心馳放 的頭像
註冊日期: 2007-07-24
E46-OBC 隱藏功能
起立.....立正....敬禮!~ .
身心馳放 目前離線   回覆時引用此篇文章
舊 2007-08-06, 10:45 PM   #34
ctc667712s
註冊日期: 2005-03-12
文章: 1,096
E46-OBC 隱藏功能
下面引用由黑皮2006/12/11 01:33pm 發表的內容:
真實用的文章!受用了~~!-=-=-=-=- 以下內容由 黑皮 在 2006年12月13日 11:35am 時新增 -=-=-=-=-
e38也可以啊,只是要輸入車身號碼! :em05:
舊 2007-12-09, 12:26 AM   #35
閻黑之城
註冊日期: 2007-04-18
文章: 212
E46-OBC 隱藏功能
不會拉...找文章地確也很辛苦~而且大大還熱心的po上來分享~超讚的拉....謝謝ㄌ
閻黑之城 目前離線   回覆時引用此篇文章
舊 2007-12-14, 12:45 AM   #36
mimi
註冊日期: 2007-10-22
文章: 34
E46-OBC 隱藏功能
以前有朋友交我E36的..請問有人知道嗎?? 我的車是98年的..謝謝
mimi 目前離線   回覆時引用此篇文章
舊 2007-12-17, 02:04 AM   #37
蛋王
蛋王 的頭像
註冊日期: 2007-01-27
文章: 988
車型: .E92.E93.E60.E70.F10
E46-OBC 隱藏功能
這個東西在博士通維修技術手冊上有完整版
蛋王 目前離線   回覆時引用此篇文章
舊 2007-12-17, 09:53 PM   #38
Bens
註冊日期: 2004-01-01
文章: 96
E46-OBC 隱藏功能
下面引用由蛋王2007/12/17 02:04am 發表的內容:
這個東西在博士通維修技術手冊上有完整版
小弟愚昧,請教蛋王,關於博士通維修技術手冊,哪裡可以找的到,謝謝
Bens 目前離線   回覆時引用此篇文章
舊 2007-12-22, 02:09 AM   #39
龐克
註冊日期: 2007-11-06
文章: 225
車型: E92-335
E46-OBC 隱藏功能
1.按住里程歸零鍵超過五秒。
來個中文就對了
感謝大大分享
龐克 目前離線   回覆時引用此篇文章
舊 2007-12-24, 11:28 PM   #40
閻黑之城
註冊日期: 2007-04-18
文章: 212
E46-OBC 隱藏功能
詳細而精闢ㄉ說明!最讚ㄉ是還有翻譯中文~
閻黑之城 目前離線   回覆時引用此篇文章
舊 2008-01-29, 02:24 PM   #41
興仔
註冊日期: 2008-01-22
文章: 62
E46-OBC 隱藏功能
太棒了....感恩啦!!
興仔 目前離線   回覆時引用此篇文章
舊 2008-02-03, 12:21 PM   #42
信益
註冊日期: 2007-03-20
住址: 桃園///M3
E46-OBC 隱藏功能
感謝感謝~
信益 目前離線   回覆時引用此篇文章
舊 2008-02-13, 09:29 PM   #43
大頭呆
註冊日期: 2006-06-10
E46-OBC 隱藏功能
好東西謝謝前輩發表
大頭呆 目前離線   回覆時引用此篇文章
舊 2008-04-10, 09:48 PM   #44
Andy999
Andy999 的頭像
註冊日期: 2008-02-04
住址: 台北內湖
文章: 270
車型: G11
E46-OBC 隱藏功能
各位車友.救救我.
1.不小心按到(21)儀表版重新歸零.那怎麼辦呢?
2.要如何開啟或關閉測試功能(19)
Andy999 目前離線   回覆時引用此篇文章
舊 2008-04-10, 10:22 PM   #45
NOS-阿志
NOS-阿志 的頭像
註冊日期: 2004-11-14
住址: FB:超跑勁駒世界
文章: 2,450
車型: Aeroquip E39
E46-OBC 隱藏功能
下面引用由Andy9992008/04/10 09:48pm 發表的內容:
各位車友.救救我.
碼表歸零鍵按住不放約5秒鐘開始顯示1.一直按到2.3.......到19放開約1~2秒變成ON在趕緊按一下,接著就可按到你所想看的了!
舊 2008-04-12, 12:32 AM   #46
Andy999
Andy999 的頭像
註冊日期: 2008-02-04
住址: 台北內湖
文章: 270
車型: G11
E46-OBC 隱藏功能
很擔心會有什麼影響嗎?[br][br]-=-=-=-=- 以下內容由 Andy9992008年04月12日 00:35am 時新增 -=-=-=-=-
目前只能看到 1.2.的功能.其他全部看不到.是哪裡出了問題?[br][br]-=-=-=-=- 以下內容由 Andy9992008年04月12日 06:53pm 時新增 -=-=-=-=-
很擔心會有什麼影響嗎?[br][br]-=-=-=-=- 以下內容由 Andy9992008年04月14日 11:33pm 時新增 -=-=-=-=-
在此感謝阿志車友介紹一位對BMW車萬是通的朋友.才讓我的問題解決.再次感謝阿志車友.
以下是得到正確的操作方法.
碼表歸零鍵按住不放約5秒鐘開始顯示1.一直按到2.3.......到19放開約1~2秒變成OFF在趕緊按一下,接著就會顯示0.再來就可按到你所想看的了!
舊 2008-05-13, 09:01 AM   #47
莫莫無名
註冊日期: 2008-04-24
文章: 37
E46-OBC 隱藏功能
整理的好細心!!感恩!!
莫莫無名 目前離線   回覆時引用此篇文章
舊 2008-05-13, 11:31 AM   #48
保誠阿毛
註冊日期: 2007-11-18
文章: 593
車型: DIO 50
E46-OBC 隱藏功能
好東西 我把它列印出來了!!謝謝前輩們^^
保誠阿毛 目前離線   回覆時引用此篇文章
舊 2008-05-18, 07:04 AM   #49
等待的心情
註冊日期: 2008-03-30
住址: 北部地區
文章: 86
E46-OBC 隱藏功能
感謝前輩們的辛苦!
等待的心情 目前離線   回覆時引用此篇文章
舊 2008-06-03, 11:36 PM   #50
老岑
註冊日期: 2008-01-05
文章: 183
E46-OBC 隱藏功能
下面引用由Andy9992008/04/12 00:32am 發表的內容:
很擔心會有什麼影響嗎?-=-=-=-=- 以下內容由 Andy999 在 2008年04月12日 00:35am 時新增 -=-=-=-=-
目前只能看到 1.2.的功能.其他全部看不到.是哪裡出了問題?-=-=-=-= ...
不好意思,請問一下,我每次都要先從19開始,然後才能進去看其它選項耶!這樣正常嗎?有沒有儲存功能呀?先謝謝囉!
老岑 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 09:36 PM
