舊 2007-09-25, 12:44 AM   #1
喵哥
喵哥 的頭像
註冊日期: 2007-09-07
文章: 80
車型: E39銀色520I
懇求98';E39 528維修電子書或正本
懇求98';E39 528中英文維修電子書或正本,歐規車德文看不懂[br][br]-=-=-=-=- 以下內容由 喵哥2007年09月26日 02:44pm 時新增 -=-=-=-=-
amin.yeh@msa.hinet.net
感恩喔
喵哥 目前離線   回覆時引用此篇文章
舊 2007-10-03, 08:00 PM   #2
n28851346
註冊日期: 2007-09-25
文章: 49
如果錢不是問題, 可買這本(正確的說法是兩本一套)
Robert Bentley 出版的 BMW 5 Series (E39) Service Manual: 1997-2002 (2 volume set), 上美國 Amazon 即可訂購, 約二週可到您手上
Book Description
525i, 528i, 530i, 540i, Sedan, Sport Wagon The BMW 5 Series (E39) Service Manual: 1997â?"2002 is a comprehensive, single source of service information and specifications for BMW 5 Series from 1997 to 2002. The aim throughout this manual has been simplicity, clarity and completeness, with practical explanations, step-by-step procedures and accurate specifications. Whether you are a professional or a do-it-yourself BMW owner, this manual will help you understand, care for and repair your E39 5 Series. Though the do-it-yourself BMW owner will find this manual indispensable as a source of detailed maintenance and repair information, the BMW owner who has no intention of working on his or her car will find that reading and owning this manual will make it possible to discuss repairs more intelligently with a professional technician. Engines covered in this BMW repair manual:
* 6-cylinder engines: M52, M52 TU, M54
* V-8 engines: M62, M62 TU Fuel injection systems covered in this BMW repair manual:
* Bosch M 5.2, M 5.2.1, ME 7.2
* Siemens MS 41.0, MS 42.0, MS 43.0 Manual transmissions covered in this BMW repair manual:
* Getrag S5D 250G, S6S 420G
* ZF S5D 320Z Automatic transmissions covered in this BMW repair manual:
* A4S 270R, A4S 310R
* A5S 360R, A5S 390R
* A5S 325Z
* A5S 560Z, A5S 440Z Technical highlights:
* Procedures from the basic oil change service to interpreting the Malfunction Indicator Light (MIL). This manual tells you what to do and how and when to do it.
* Engine and cylinder head service, including camshaft timing chain setup and adjustment.
* Information for specific driveability problems, including explanation of engine management systems and BMW OBD II Diagnostic Trouble Codes (DTCs).
* Theory of operation and repair information for the Siemens and Bosch engine management systems.
* Drivetrain maintenance, troubleshooting, adjustment and repair of self-adjusting clutch (SAC), gearshift linkage, driveshaft, and drive axles.
* Manual and automatic transmission removal, installation, seal replacement and external service.
* System description and repair information for Antilock Brakes (ABS), Automatic Stability Control (ASC) and Dynamic Stability Control (DSC).
* Heating and air conditioning repair (IHKA and IHKR), including component replacement.
* Body adjustments and repairs, including sunroof and tailgate.
* Wiring schematics and extensive electrical component section specifying relay, control module and ground locations with detailed illustrations and photos.
文字
n28851346 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 02:08 AM
