舊 2012-09-13, 02:27 PM   #1
ryan117
註冊日期: 2012-04-27
文章: 45
E39 車內儀表板檢測故障碼
我的車是E39,之前有爬文找到如何查看車內儀表板數據的相關文章。
昨天沒事看了一下車內儀表板,在14.0故障碼裡面有看到一些數據,但不知這是哪裡的故障?是否有大大知道呢?感恩。
ryan117 目前離線   回覆時引用此篇文章
舊 2012-09-14, 12:49 AM   #2
ryan117
註冊日期: 2012-04-27
文章: 45
自推,只能找時間GT1一下了.....
舊 2012-09-14, 02:04 AM   #3
儀表板的測試 14項是儲存電腦中的故障碼!
取前的數字為代表意思
14.0 BEC82D BE代表燈光模組內部的錯誤( LCM internal error)
14.1 834228 8代表右邊的浮筒有問題(Fuel level sensor 1 )
14.2 D78115 D7代表左邊的浮筒有問題(Fuel tank sensor 2)
1 Fuel consuming signal from engine control unit faulty
2 Fuel consuming signal (ti-II) from engine control unit faulty
3 Road signal from ABS/ASC/DSC control unit faulty
4 RPM (tD) from engine control unit faulty
5 Coolant temperature sensor faulty
6 Temperature sensor
7 Outside temperature sensor
8 Fuel level sensor 1 (Fuel pump side)
9 Fuel level sensor 2 (without fuel pump)
10 Tension to high at the power supply
11 EGS signal disturbed
12 Power supply Pin 15
13 Power supply Pin R
14 Service Interval Display (SAI) Reset
15 Pressure Switch
16 Gong Sound (T1)
17 Gong Sound (T2)
18 Gong Sound (T3)
19 Current to high in the instrument cluster
20 Internal error in the LCM module
21 Internal error (IKE)
22 Vehicle speed signal (Tacho-A)
23 Instrument cluster -Bus (I-Bus)
24 Body-Bus (K-Bus)
25 Error during activation of the instrument in the instrument cluster
26 Undefined error
27 Internal Error
28 I-BUS error
29 Power Supply
30 Power Supply
31 Power Supply
32 Power Supply
33 K-BUS
34 Oil Pressure Control Light
35 Reverse gear recognition
3E Error by activation display
3F Instrument cluster current to high
44 Oil pressure switch
87 Body-Bus (K-Bus)
88 (I-Bus)
8B Gong Ton (T3)
8C Power supply Term. R
8D EGS Data lead disturbed
8F Power supply
90 Power supply Term. 15
91 Gong Ton (T2)
92 Gong Ton (T1)
BC Break fluid level
BD Electronic break power
BE LCM internal error
BF Instrument Cluster Internal Error
C1 ABS/ASC/DSC Signal(Tacho)
C3 RPM signal from DME control unit
C6 Output PIN 6 (Code EWS)
C7 Fuel tank sensor 1 (fuel pump side)
CD Fuel consumption signal DME 1
CE Outside temperature sensor
CF Service Interval Display (SIA) Reset
D3 Coolant temperature sensor
D5 Oil temperature sensor
D7 Fuel tank sensor 2 (without fuel pump)
DA Fuel consumption signal DME 2
F0 CAN-Bus off
F4 CAN Identification missing
F5 CAN Identification missing (ASC)
F6 CAN Identification missing (DME)
F7 CAN Identification missing (DME)
F8 CAN Identification missing (DME)
F9 CAN Identification missing (DME)
FA CAN Identification missing (EML)
FB CAN Identification missing (EGS)
FC CAN Identification missing
FD CAN Identification missing
舊 2012-09-14, 12:05 PM   #4
ryan117
註冊日期: 2012-04-27
文章: 45
了解了。感謝站長小樂大大詳細解說。
舊 2012-09-14, 06:28 PM   #5
wind0123
註冊日期: 2011-04-21
文章: 419
車型: E39-523
樂大:
您的這些資料是哪找的啊?
風城~~自由的風~~
wind0123 目前離線   回覆時引用此篇文章
舊 2012-09-14, 08:39 PM   #6
ryan117
註冊日期: 2012-04-27
文章: 45
另外再請問樂大,以上的3個故障碼會有影響嗎?
我的儀表板上面有些燈(引擎燈、右邊紅色驚嘆號燈)開紅火時都不會亮,且打左方向燈時,有時會閃很快,這也是因為燈光模組的問題嗎?
左右邊的浮筒問題會有怎樣的影響呢?
謝謝。
所有時間均為台北時間。現在的時間是 08:48 PM
